Charging Plug Adapter - Will this work?
ArthurDOB
Arthur
High School Teacher
My father-in-law has an arc welding setup in his pole barn at his place. It uses a 6-50 receptacle on a 50A circuit. WIll this adapter work with the Ford portable charger?
Ford Mustang Mach-E Charging Plug Adapter - Will this work? Screenshot_20230820_180703_Amazon Shopping
Make sure the adapter has a minimum wire size of 8AWG. Other than that, it should work fine. ??
ocdxfv
Matt
Orange County, CA
Retired radiology tech
If you already have the adapter, check the wire size and make sure it says it's at least 8AWG. If is says 10AWG, don't use it. The Ford portable charger runs at 32a so #8 wire is fine and #6 is even better if you have the option.
If you don't have the adapter and are going to order one, I wouldn't recommend buying one unless you can verify the wire size is #6 or #8. If it doesn't say what the wire size is, buy one that does.
glenthompson
Glen
Williamsburg VA
2022 Mustang Mach-E GT Star White
I think that is a 15 amp plug for connecting a 50 amp RV to a standard 120v household receptacle. I doubt the plug will fit into his welder receptacle since typically has two slanted prongs for the hot wires.
ATL
Canada
1979 Trans Am, 2016 Mustang GT
Electrical Engineer
No it just looks like that because you can't tell the size from a picture with no scale. It's a NEMA 6-50 like the OP Says. The adapter's neutral slot in the NEMA14-50 receptacle just won't have anything connected to it. That's ok in this application since EVSE doesn't use the neutral.
The 50 A plug has straight slots. A 30 A plug has slanted slots like a campground receptacle. Welders would use a plug standard compatible with their full load requirements.
If you blow up the image you can see where "N6-50P" is embossed on the plug head, near the larger flat prong. ??
glenthompson
Glen
Williamsburg VA
Missed that. Last welder I had used a 10-30 plug. Have not encountered N6-50P. This should work fine since the charger doesn't need the neutral, just the two hots and the ground. I would check to see if the neutral in the 14-50R is connected to anything.
Tbird
Denny
New Hampshire
MachE GT 2025 (with Perf Upgrade), 2024 Kia EV6 GT-Line Trim
The Ford Portable Charger requires a ground connection. No ground and it will not work
Yep and it does not require a Neutral. The 6-50 provides everything except the Neutral. ?? Of course, dependent on how the adapter is wired, anything is possible. ?‍♂?
The one pictured does not have the neutral connected to anything. It should be fine for an EVSE, but don’t plug your RV into it.
ArthurDOB
ArthurDOB
Arthur
High School Teacher
Thanks for all the great advice. I knew you all would come through!?
