Charging Speeds between EVSE Brands
bncwhite
Bradley
Oklahoma City
'21 GB MME GT
Grooper Senior Tech
I’m trying to decide between a hardwire and a plug-in install. I have to get a circuit installed either way. In my research, I noticed these differences between ChargePoint and Ford’s Connected Charge Station. Just looking at the recharge rates below, is the ChargePoint EVSE 48A really that much more powerful/faster than Ford’s EVSE 48A install?
Also, I’m wanting a contactor design instead of solid state design but I haven’t found which type these two are so if you know their design that would be helpful too.
Ford:
48A Hardwired 28MPH
30A Mobile Plug-In 20MPH
ChargePoint:
48A Hardwired 36MPH
40A Plug-In 30MPH
32A Plug-In 25MPH
Ford's numbers are specific to the Mach-E, and are approximate calculated values (read the footnotes).
ChargePoint's numbers are approximate.
Neither will be correct, because it will depend on the actual watts delivered to the vehicle, which won't be what leaves the wall.
On the Ford charger, you missed the part where the 12A is using 120v, not 240v, whereas the ChargePoint is still using 240v.
Before you pick a charger, make sure you see whether your utility company provides rebates or sells chargers at a discount. Mine required either the ChargePoint Flex, or any JuiceBox.
bncwhite
bncwhite
Bradley
Oklahoma City
'21 GB MME GT
Grooper Senior Tech
Great clarification. I saw the footnotes and didn’t mention them. They kinda made it harder to make a decision. I didn’t mention the voltages either since I figured the voltage could be inferred by the amps.
Do you think ChargePoint would be faster overall?
ARK
Los Angeles
'21 Premium SR AWD
The ChargePoint Home Flex and Ford Connected Charge Station both would be charging at the exact same speed if on 48amps. As it happens, 48amps is the fastest L2 charge rate that the Mach-E can handle.
Don’t think of chargers as providing miles per hour in charge, that’s not a good way to compare them because it varies between every type of car, and even between variants of the same car.
It’s like with gas, we don’t talk about going to the gas station to fill up an extra 100 miles, we talk in terms of gallons. This is because 1 gallon goes a lot further on a Toyota Prius than a Ford Expedition. It’s like if a gas station advertised, $4.50 per 35 miles of range - well, whether you get 35 miles, or more, or less depends on your car’s MPG. It’s the exact same when it comes to electricity flowing into a battery - depends on the car how far that same amount of electricity will take you.
So long story short, when you are looking at different chargers, comparing the amp rate between them is key (assuming we are talking about 240v charging).
bncwhite
bncwhite
Bradley
Oklahoma City
'21 GB MME GT
Grooper Senior Tech
This conversation is referring to 240v. I’m not considering 110v since that is too slow for my needs. Maybe I should edit the original post and remove that part.
You should also understand that some chargers allow a modification of the charging speed, up or down, via the app. Some chargers require you to set DIP switches.
JuiceBox chargers do it via the app. I believe Ford is DIP switches.
No. With the same amperage, they will deliver the exact same amount of charge per hour.
Av8tor
Kevin
Richmond, VA
Fusion Hybrid, MME GTPE
Systems Engineer IOT
Ford:
48A Hardwired 28MPH
ChargePoint:
48A Hardwired 36MPH
40A Plug-In 30MPH
32A Plug-In 25MPH
I just had a ChargePoint installed in prep for mine. The electrician said he always prefers hardwiring anything. One less point to fail. You can always add a plug later if you can't deal with the hardwired.
The other thing you have to figure out is what your house will support. I could only put in a 50 amp connection. The ChargePoint can connect up to 80 amps, but I would have to spend a boat load of money upgrading my panel in the house. Not worth the extra 7 miles an hour.
Difference between 60A and 50A is only 6 miles.
Ford Mustang Mach-E Charging Speeds between EVSE Brands 1639866503520
Ford Mustang Mach-E Charging Speeds between EVSE Brands 1639866517034
Ford Mustang Mach-E Charging Speeds between EVSE Brands 1639866523776
Av8tor
Kevin
Richmond, VA
Also, have a conversation with the electrician, I had a long run from my panel in the basement to the garage. He used aluminum wire, like they use when they connect your AC unit to your house, from the panel to a box with a cut off plug, then copper to the unit.
Copper right now is very expensive
$850 to install 50A breaker, plus move a few to make room, about 85 feet of wire to the garage, that cut off box, and copper and conduit to the unit.
Ford Mustang Mach-E Charging Speeds between EVSE Brands 1639867808649
The max current of the FCCS is set by DIP switches, but it can be set lower in the app. This (DIP switch limit) gives the flexibility to install it on a lower power circuit in case a 60A is not available.
I got corrected on this a week or so ago.
Garbone
Gary
Loafer
Also consider cord length. I bought my GrizzlE specifically due to it having a longer cable giving a bit more freedom in parking.
Agree….the 20’ cable length is the one thing I don’t like about the FCCS. Another two feet and I’d be able to charge a car in either stall of my garage.
Agree. My JuiceBox 48 has a 25' cord. Actually, around 24' 3".
Ford:
48A Hardwired 28MPH
ChargePoint:
48A Hardwired 36MPH
40A Plug-In 30MPH
32A Plug-In 25MPH
The ChargePoint Home Flex and Ford Connected Wall unit are both contactor type. Those units just supply power to the charging unit which is located in the car.
So, the charger is in the car which means the charging speed is the same between the two EVSE units listed above (all else being equal).
Even though the ChargePoint Home Flex is capable of providing 50A.....the Mach-E can't accept that much power so it will draw 48A.
Hope this helps.
bncwhite
bncwhite
Bradley
Oklahoma City
'21 GB MME GT
Grooper Senior Tech
I guess now I need to go with the FCCS in hopes Ford puts out new features to it to use with the Mach-E or go with Chargepoint for a longer cord and smaller footprint.
Check out what Emporia is offering. I have their charger and it is Wifi enabled and linked their their power monitoring app. You can hardwire it or plug it in. The hardwire lets you charge at 48 amps. I am very happy with it.
https://www.emporiaenergy.com/emporia-ev-charger
Ford Mustang Mach-E Charging Speeds between EVSE Brands 20211210_194845
Ford Mustang Mach-E Charging Speeds between EVSE Brands Screenshot_20211210-195959
Ford Mustang Mach-E Charging Speeds between EVSE Brands Screenshot_20211210-201637
