CR report on EV range tests
kindofblue
Reid
Arroyo Grande CA
Grabber Blue Mach e Premium 11/5/22, '25 Lexus 45h+ PHEV
Ford just posted this and I confirmed it on consumer reports (but it's behind a paywall so can't link to it).
Range reports of EVs in different temps
It was nice to see that the ranges of the Mach e were virtually identical to the Tesla MY.
Note - if you belong to a public library, you may have FREE access to the entire Consumer Reports database. Visit your library's website. Once logged into the site, you click on the CR link and sometimes put in your library's info and you're good to go.
x19
Eric
Chicagoland
Mach-E 2023 Premium AWD ER pending dealer order
IT Engineer
I would love for the EPA to adopt a 3-part label/rating like CR used, rather than the single rating they have today.
Blue highway
Mach E Premium SR RWD
Getting ready for the flood of "where did my range go" posts this winter, this should be sticky.
according to CR, if I read this right,
Cold =16 degrees
Mild = 50 degrees
Warm = 80 degrees
A reminder that "cold" means different things to different people.
Blue highway
I'm actually confused why they included the Ioniq 5 in this test, they didn't even test it in the cold, totally weird move by CR.
FWIW our SR RWD MME delivers similar numbers to the ID4 above although "cold" here is around freezing.
your mileage may vary
Plus, they spelled it “Ionic!”
lurker
Mach-E E4X
SWE
It is awesome that Ford is on the dot with their EPA estimates. When I had my M3 LR, I know it was not going the full 350+ miles it was advertising. With my wife's Mach E, the GOM has been very accurate. I have been able to subtract almost the exact miles I travelled from the starting range estimate to my destination ending range.
roamtheworld
Austin, TX
2025 Mach E Rally in Molten Magenta
Nice to see CR testing in this format. This will help many understand the differences temperature has on EVs. I hope more data like this is provided in the future.
Other countries do perform this kind of testing like Norway. Here is a 2021 report that includes winter and summer range results. https://insideevs.com/news/512426/norway-ev-summer-range-test/
Bonehead
Malibu
'25 MME GT Performance ('21 MME Premium AWD Ex)
The article says they bought the Ioniq 5 after the winter test, and they will test it this winter when the temperature is the same as the first test.
Lloydian
Lloyd
Phoenix, AZ
2021 Mach-E GT PE
Bookkeeper
Okay, how is Tesla's "Official EPA" mileage 20% higher than what you get in the best of circumstances? Does EPA simply trust manufacturers to tell the truth?
moparguy
They should have tested my Mach E, because after a lot of slow driving I barely touched 248/270
My usual was 220-230.
