Neil4Real
If you buy from KeylessEntryRemote, are they used? Their eBay page says they only sell used fobs that they make sure work which is why they’re so cheap, but they might have scratches, etc. if that’s the case, I’ll buy, just wasn’t sure if the initial ones everyone got were actually brand new.
Yes, they’re used. Not really sure how they had so many used Lightning fobs already. The one I received was in fine shape, so I was happy to not have to pay full retail from the dealer.
su-ch+mache
carl
Germany
www.ford-suv-freunde.com
Escape MY17, Puma MY20, Mach E MY22 AWD ER TP2
retired buyer
hi, has anyone tried this function on a MY22?
hopefully I will get mine in Dec. and would like to have a key to open the frunk.
@Mike G is there really nothing to be reconfigured on any modules? no programming?
Do you know how this function works?
i8iridium
Pat
Fort Washington, MD
2022 Mustang Mach E GT
U.S. Air Force (ret.)
Nothing is required besides the FOB in the '22s. If you have two FOBs, which you should if you have a 22, you can do the programming yourself.
It's super simple. Drop FOB 1 in the programming slot inside the console, Start vehicle, turn off. Drop FOB 2 in, Start, turn off. Then drop new un-programmed FOB in the slot, Turn vehicle on. Should be done.
Avelli
NorCal
E91 6MT RWD, 22 MME GT
Got mine from the dealer; Cost $200+, and the FordPass points only covered $110 of it, so out $100 out-of-pocket. Not ideal :rolleyes:
I'm having difficulty programming, though.
1. Do you step on the brake for the "press ignition button" steps?
2. How do you isolate the programmed keys? I think my Mach-E is picking up the programmed keys when I put the last (unprogrammed) key in, giving me a false positive.
SWO
MD, USA
I believe you have 5 seconds between moving keys so it's best to have them lined up and move fast.
i8iridium
Pat
Fort Washington, MD
I stepped on the brake so the car was in "ready" mode. You have the FOB completely in the slot in the center console? That's the only way it reads the FOB for programming, you don't need to isolate the others. And yes, as @SWO said, you gotta be fast.
When you put the key fob in the slot, push it toward the front of the car a bit to make sure the back of the fob is in full contact with the wall of the console. You only have to hold it there for a few seconds for it to register.
Mike G
Mike G
N. AL, USA
The two I got were brand new.
Mike G
Mike G
N. AL, USA
Also, I had no success programming the fob initially following the instructions. I dropped by the dealership to discuss something else and the service manager came out to the car and it was done in about 30 seconds. The issue was that the driver's door had to stay open. The instructions say to close the door.
When the programming is successful you'll see a brief message on the IPC about a security code or whatever and that's how you know it took.
I did it with the door closed. Total operation took less than 30 seconds, but I held the fobs each time to make sure they were making good contact.
Mike G
Mike G
N. AL, USA
Yes but you're special. You have the frunk button already stored in your asbuilt! :cool:
