So, my 3rd key programmed successfully. However, the frunk button does not work. All the other buttons work fine. I have a 2021 Mach-E that I assume is a job one. Purchased in early July of 2021. Any suggestions?
Did you or your dealer update the BCM and GFM modules? That’s a prerequisite for Job 1 cars.
Kachook
Houston
2021 Mach-E Premium AWD, 2016 Honda Odyssey
No, I do not know what that is, so I did not. I never asked the dealer to do it, so I will ask them when I go for my next tire rotation. Hopefully, it will not be a charge.
There’s also a routine to add the frunk button to the Sync screen that they’ll have to run for the button to show up there. Hopefully, they won’t charge you, but there is no official bulletin from Ford for enabling the frunk.
e-pony
SoCal
Premium AWD Extended Star White
FYI anyone going this route, fairly easy to pop out the button: push in on the little tab holes, pry apart gently and presto, extra buttons. Now I just need the Lightning one back in stock.
Does anyone know if the Mach e fob has 5 buttons, the bottom one covered by the black plastic shell? If it does, one could DIY drill or cut hole in the plastic cover, and insert a console ps5 button or piece of silicone, etc. to act as the external button cover. Then program. Not elegant but f150 lightening fobs are out of stock ( other than 200 dollar dealer or ebay used fobs).
flapjake314
NYC
Mach-E Select AWD
i'm a bit confused by this + the other thread about 2021 job1 never getting frunk button on fordpass. does the lightening key fob work with 2021 job1?
i see someone recently posted they couldn't get it to work with theirs but i can't tell if it's a fluke?
do we think this will eventually come via OTA? Because I got that fob and paired it successfully with my car but it doesn't open the frunk :(
Depends who you ask. But since you’re asking me, I do think it will come OTA some day.
The sceptic in me say the OTA won't happen until after @Jimrpa has it done by his dealer (or by an FDRS intervention) ?
Even if Jim gets the GFM and BCM updates they still have that inhibit code preventing his account from having a frunk button. ??
SpaceEVDriver
Planetary Science
I did this programming a few weeks ago. This past week I was in and out of the frunk a dozen times. Not once did I remember I had this key and I opened the driver door each time.
LOL.
Sigh.
CAL465
Jorge
Benicia
2023 Mach e Premium
Just curious. Does anyone know the part number for the F150 OEM keyfob?
Well, it’s going in on Monday and I’ve given them has explicit instructions as possible (there’s no way to give them the verbatim instructions and screenshots people gave me ?). So, by Monday night, I expect to be mashing the 7/8 key repeatedly, in disappointment, as nothing happens ?
