Does 1430 KWh in one month seem right?
physib
N/A
Did some math and that's what my first month of home charging consumed. That's like charging from 20% to 85% 25 times over. I have made a few longer trips (1-200 miles), but I've also used charging stations for those. I have about 2600 miles on the odo, and I'm usually hovering around 3 mi/kwh.
benk016
Ben
Tulsa, Oklahoma
2021 Mustang Mach-E GT
Just looked at my ChargePoint history. Keep in mind I haven't been driving a whole lot since i'm working from home:
October:
424 kWh
1283 estimated miles driven
November:
606 kWh
1723 Estimated miles driven
That comes out to less than 2 miles/kwhr. Does not seem right.
Where are you getting your 1430 number?
Peugfan
Minnesota
2017 Linc MKX, 2021 MME Prem 4EX Infinite Blue
No, sounds a bit high on kwh's. How are you getting your kwh numbers….charger app, estimate from home energy bill?
All Hat No Cattle
Las Vegas
2023 Genesis GV-80 , 2017 Edge Titanium
And that does not take into account the road trip charging stations.
I think someone may be siphoning kilowatts from your MME. :D
bruceski88
Bruce
CA
Mach e
Retired Engineer
20 to 85% 25 times is about 1500kWhr
physib
physib
N/A
I compared the bill to november of last year and that's the difference.. Other than the EV, there's nothing else that would contribute to this much of a variance.
physib
physib
N/A
Yeah I also work from home, so that electricity bill definitely shocked me.
romanservices
2021 MME GTPE, FJ Cruiser, F150 EcoBoost, F-53
Just looked at my charge point.
November 461 kWh $55.00
October 564 kWh $71.00
Car has 2331 miles and we got it in early October and have only charged at home. Average 2.27 miles per kWh.
$116.00 in electricity
Technically, one would siphon “kilowatt-hours”, not “kilowatts.”
physib
physib
N/A
Really don't think they'll be able to help but I guess I'll call Grizzle CS tomorrow
KrazyEd
Ed
Las Vegas, NV
Carbonized Gray Metallic Premium Mustang Mach E
Transportation
There is some overhead to charging. not sure what it is, but only for math, let's call it 1/2 KW Per hour. If you are using 120 Volt for home charging then it draws approximately 1.2 KW per hour, minus the .5KW Per hour, you are only delivering .75KW to the car. If you are charging using the supplied
charger at 240 Volts, assume 7KW delivered minus the .5KW so getting 6.5 KW. Using 120 Volts would probably account for the difference. If using 240 volt, then, probably not. Also, if you are
Pre Conditioning ( you should be ), then this will also add to energy used that may not be appropriately accounted for.
Tip - if 120v charging, buy a Killowatt and measure it.
Tip - Read meter. Plug in and charge. When done, read meter.
Motomax
Max
VW GLI, 4Runner
That's true, but still doesn't explain how my consumption in one month is equal to more than twice of others'.
It’s really simple, take you average monthly miles (minus when you charged away from home) and divide it by your m/kWh average. That gives you the best estimate, you can’t compare to other people since driving habits make a huge impact. If my average is 4m/kWh and yours is 3m/KWh - you are going to use 25% more energy charging.
Doesn’t your utilities give you consumption down to each hour? Should be easy to calculate based on when you charge the car.
also, don’t waste time calling the “charger” manufacturer. It’s just a fancy switch it won’t be using a bunch of energy unless you’ve got a leak to ground-you would know.
