Estimated Range = 509 Miles
N2bonz54
Don
Mach E Premium 2WD Extended Range
Physician
Had a problem with my front camera defaulting which would kick off the Blue Cruise, Lane keep and emergency braking. After I got the car home from the dealership for 48 hrs the estimated range showed 509 miles. It has not changed in 5 days they a couple of charge cycles. Stuck at 509.I was typically showing around 295 at 85% charge.
Called Ford tech support. They had no suggestions other than return the car to dealership.
Not a critical issue until I take a road trip. Any suggestions out there? 2021 RWD Premium
Ford Mustang Mach-E Estimated Range = 509 Miles PXL_20240412_151900832.MP
Jerrytball
Jerry
Gulfport MS
2026 bmw i4 M50
I’m just gonna suggest what all the guys tell me whenever I’ve had an issue. Have you pulled the negative cable on the battery? I suppose if you know which fuse deals with the display cluster in front of the steering wheel, you could pull that fuse and put it back in after 10 minutes, other than that, I don’t know what else to say.
It's not a critical issue at all. It's meaningless. Just drive the car.
Prior to taking a trip, on a local drive, set a destination and see if it adjusts. Then, cancel the route and see what happens.
If all else fails, delete your EV history.
But don't waste your time taking it in to the dealership.
ArthurDOB
Arthur
High School Teacher
The range of everyone's dreams! :D
BMT1071
Glendale, AZ
21 MME SR RWD, 23 MME GTPE
EV Technical Trainer
Have you tried resetting driving history through the SYNC screen?
N2bonz54
N2bonz54
Don
Physician
I deleted the history and the milage reset. I'll follow it to see if it updates as I drive it.....Thanx for the suggestion.
N2bonz54
N2bonz54
Don
Physician
Funny, I thought about deleting the driving history, but when Ford tech support they had no solutions I assumed that something as simple as resetting the driving history wouldn't work.
Thanx for all the responses....
Very sad that Ford Tech Support could not answer this very basic question. Very sad.
mkazen
Marc
Gurnee, IL
Mach E GT
Just pay attention to the percentage charge as the GOM isn't usually accurate anyway. Using ABRP you'll utilize the percentage anyway.
67 Stang Convertible
Rich
Georgia, USA
Physician
I default to the Forum since back in 2021 when I realized the "tech" people did not know much more than I did. And, certainly less than many of the forum members.
sparkout
Cliff
2021 Mach E 4X Premium
It's all all downhill from there
OcSteve39
Steven
Wilmington, NC
Mach E GT Performance
Keep it.
You're a Lucid now.
