Ford Power-up 4.2.6
Mike G
N. AL, USA
This update is EA I assume so I'm going to cut them some slack on the release notes....
Why would you think this is EA? Those software updates appeared in FDRS two weeks ago and they should be available to anybody who checks for updates today.
SWO
MD, USA
We're talking about the OTA release notes. It has only gone out to EA.
Drove last night. In EA. Didn't get this yet.
Mike G
N. AL, USA
Roger that...I guess it just hasn't gone wide yet. I've had at least two instances where I checked FDRS...saw updates, went to the car (or the truck) spammed the check updates button a couple of times and they showed up as OTAs. On the other hand, I just saw in FDRS this morning the Lightning versions of the latest powertrain releases, and tried spamming the check updates button and got nothing. So I got the gear out and have just finished doing those with FDRS. So it must be an issue of whenever your VIN gets the nod. I'm enrolled in EA for both my vehicles but am in no particular 'program', just enrolled. So I don't know how much weight the EA thing carries, if any.
nj-mache1
2021 MME GT-PE Iconic Silver
Got this yesterday, it reset my charge settings (had to delete and re-add to set). Luckily caught it in time and stopped charge at 80% instead of letting it sit at 100% overnight...
Haven't had a chance to drive it today to see effect on GOM. I did get the notification in FordPass regarding the Intelligent Range addition prior to downloading the update.
737flyer
Richard
Redington Beach, Fl
2025 Mache Premium, 2024 BMW IX50
Retired Airline Pilot
I’m not EA. I got the notification this morning but no software update yet.
Roger tobin
Roger
Beaverton OR
2021 Mustang Mach E Premium RWD Extended Battery
So, 4.2.6 is having a lot of trouble installing. (I'm in EA). I have tried to let it update at my normally scheduled time (3am) and also have tried it NOW (whenever that is). I think I've attempted it 6 times and it always fails.
The mesage I get in the car is: Vehicle Not Updated -- The update was cancelled because it was interrupted by another process. You can schedule a time to retry the update or try updating it again when you are ready.
What gives? @FordMotorCompany -- can you help?
Haven’t gotten it yet, but I have that weird 4.2.5 problem, so ?‍♂ @Ford Motor Company , a little help here as well please?
MacherAWD
North Shore MA
Healthcare Software
I had that twice last night, I was in the yard near it. It later installed fine.
Yours is failing because your 12V battery is only about 20% SoC (which is another problem you should fix). Looks like you don't drive much? You need to leave the car on or charge it for about 3 hours immediately before starting the update.
MacherAWD
North Shore MA
Healthcare Software
Tell her to pull over, park it and tap that update button now! ;)
I almost did, she was taking our boys for haircuts, so I knew it would be parked for 30+ min
Roger tobin
Roger
Beaverton OR
It IS on the charger when it tries to update at 3AM. . . . plugged in usually at 9pm.
