Gullwingdmc
Chip
Boston, MA
I should be able to fix the shortcuts. Can you send me a link?
You are the best.
This is where the shortcuts originated from. The first 3 are the important ones.
Settings is where you enter your info
Token gets the auth token
Get Vehicle status gets all the info.
Then there are individual shortcuts that send or retrieve data. Ones like lock, unlock, and start.
The benefit to the shortcuts is you can have Siri run them and ask Siri for the status of your car.
I wrote one this weekend that runs every night to confirm if the car is locked, if it’s plugged in, and if it’s charging.
tonesto7
tonesto7
Anthony
Ann Arbor, Michigan
2021 F150
You are the best.
Thanks. I started writing a shortcut that works with the widget that allows voice interaction and voice control. Never finished it
Gullwingdmc
Chip
Boston, MA
Nice! I’m hoping the new API can be used the same way the old one could. These are all the shortcuts I had added or created to take advantage of all the data it returns. I had a few setup to activate when I scanned NFC tags by my garage door so I could start the car or unlock it.
Ford Mustang Mach-E FordPass - Scriptable Widget V2022.XX (iOS, iPad, MacOS) 1655950386598
Ford Mustang Mach-E FordPass - Scriptable Widget V2022.XX (iOS, iPad, MacOS) 1655950415432
GrisGris
Tampa
'21 Premium RR ER AWD
Is the widget still working for everyone? It seems like the Apple shortcuts have stopped working because the address they hit is now returning nothing. Same with the update status.
Yeah, mine is acting a bit wonky. It's reporting the doors unlocked when they definitely aren't.
OTA Update info is also broken. Getting nothing but an "Invalid Credentials" (400/Bad Request) error. Or is that something I can fix on my end? I searched this thread for that error but didn't find anything.
mikeinet
New York
Standard AWD Tech/Comfort
I was getting the OTA errors too.... tried to update the app... now i'm just totally hosed
ocr_salty
UK
Mach-E SR RWD, Nissan Leaf
Aerospace Engineer
Same here, didn’t update for a long time, showing the car as running. I’ve tried removing it completely but now can’t reinstall it, get an error.
tonesto7
tonesto7
Anthony
Ann Arbor, Michigan
2021 F150
NOTICE: Ford made some more changes to the authentication endpoints which prevents third-party integrations from getting a valid token.
I'm working with @kennelh to find a new method and will push out an update once we do.
ocr_salty
UK
Aerospace Engineer
Hope you find a way around this, and that it doesn’t affect ALL third parties, I rely on a third party via my energy supplier to schedule all my charges.
Shayne
Northern Ontario Canada
2021 MME4x Prem
Felt like it was Ford plugging a hole. Reverse engineer that baby and get us up and running again on an app that works. ?
Ravensfan1996
Rick
2021 Mustang Mach E
so thats why it hasn’t worked the last few days? Thanks hope it can be fixed.
KevinS
Thank you for the update and explanation. I had no idea how addicted I was to this script until the past few days!
tonesto7
tonesto7
Anthony
Ann Arbor, Michigan
2021 F150
I'm getting close... I would have this done already if there weren't so many limitations to the Scriptable Javascript environment.
I'm still chugging along day by day trying to resolve the issues.
ocr_salty
UK
Aerospace Engineer
Thank you for all your efforts and work you've put into this, I'm sure if you set up a 'buy me a coffee' page you'll get a lot of donations!
Marc S
Marc
United States
2021 Select (lease ended) Now 2023 GTPE
There is already a page for this. Scroll back in the thread
