FORScan MME spreadsheet
Neil4Real
Interesting. I have a 2022 GTPE but I have never noticed any difference in 1PD between modes. Is unbridled more aggressive? How are they different?
In Unbridle, my car definitely slows down more aggressively when I let off the accelerator, compared to Whisper. Maybe I'm just going crazy or it only does it more aggressively at higher or lower speeds as other people also say they don't notice it, but you can really feel the braking in Unbridle.
Larry Paul
Larry
MME-GTPE, Sunbeam Tiger w1970 Boss302, 2002Rav4EV
Thank you. I will see if I can detect a difference between modes with 1PD. My preference is to have a paddle that can offer more aggressive braking, but that is not going to happen.
If there is a difference, I would really love it if the "L" button could be used to toggle to more or less aggressive 1PD. Currently if the 1PD is on-the "L" is not active.
CarGuy11
Pittsburgh
2022 MachE4X Prem, 2020 GRSupra, 2016 Corvette Z51, 2024 Emira
No, the hardware isn’t there to run the side sensors.
I would think there is 1 module that control all of the ultrasonics.
kkmoon
Vancouver, WA
2022 MME GT
I was in the camp that 1PD braking was more aggressive in unbridle. Feels like it to me. Then I did several 70-0 stops on the same stretch of road with foot completely off the accelerator. Almost exactly the same max regen in all three modes. I think maybe it just feels like more regen in unbridle because of the pedal mapping. Seems to come on stronger but the max is still the same.
Larry Paul
Larry
Thank you-that seems to match my experience. I generally start backing off the accelerator gradually in any driving mode- or go to max and I have not noticed a difference with 1PD.
I really do wish Ford would use the "L" for a more aggressive 1PD.
LaFong
LaFong
Colorado
Mustang Mach-E GT 2024 Vapor Blue Metallic
Systems Engineer
Might be the APIM 7D0-08-01 module, though I’m not sure that helps. Mine is set to
7D0-08-01 C000 0002 00A2
Correct, but the ultrasonic board in the new ones doesn't have the input channels for the side sensors. Only the front and rear sensors.
7D0-08-01C000000200A2
Parking sensors are a sub-module of the IPMA that is not addressable externally.
CYBER-O
Daniel
Richmond, BC
2022 Mach-E4X
Independant IT Consultant, Lyft & Uber driver
markboris
Sonora, CA
CYBER-O
Daniel
Richmond, BC
2022 Mach-E4X
Thanks! It's virtually impossible to drive and be outside to listen to the car at the same time!
Earlofsandwich
Nick
Canada
Mach E Select AWD
Could you be more specific?
sorry, I have a 2022 select - i was wondering if the ambient lighting is just disabled and if possible how to turn it on. I was able to turn on the setting on the screen through FORscan but wondering if there is also another module that needs to get turned on as well.
LaFong
LaFong
Colorado
Systems Engineer
afaik the Select just does not have ambient lighting. I was able to show the AM radio tab and hands-free liftgate on the screen, but there still is none in the car. :confused:
