FORScan MME spreadsheet
Did someone figure out what this is? I am curious.
Back in '21 I messed around with it. Nothing changed. Have not looked since.
Aulander
Italy
Mustang Mach-E Premium AWD
I enabled in Forscan the chime for speed limit but, after switching it on, it immediately turns off. Anyone tested this?
Ford Mustang Mach-E FORScan MME spreadsheet ch2
Ford Mustang Mach-E FORScan MME spreadsheet ch1
Ford Mustang Mach-E FORScan MME spreadsheet ch3
rugedraw
Javier
Miami, FL
Auto Sales
Adding the APIM change may only enable the toggle and not the feature itself. Some things require config changes to more than module for it to actually work.
Maybe the key is in here?
Ford Mustang Mach-E FORScan MME spreadsheet 1731627101501-ua
Right now, your car shows this:
Ford Mustang Mach-E FORScan MME spreadsheet 1731627486725-f
I would try xxxx F8xx xx--
Reboot the IPMA and test it. F8 there will turn everything on having to do with the speed change chime.
Aulander
Italy
Thanks @rugedraw for your advice. I tried to set F8 but after saving the setting stays on 0000. I tried also to enable TSRS in the IPMA setting list but the chime toggle on screen always turns off.
rugedraw
Javier
Miami, FL
Auto Sales
Maybe try one independent of the other one. With my FORScan experiments, I've found that if you enable two events at once that clash with each other, FORScan will smartly revert the changes back. I would try just the 8 first and then just the F. If none of those work, I'm out of ideas for now. I'd have to dig through the spreadsheet to see if I find anything related to that.
Aulander
Italy
No way unfortunately. The setting always stays on 0000. Maybe that setting is not for our MME or the module software version is not the right one.
rugedraw
Javier
Miami, FL
Auto Sales
Not sure. I did find that in the MME spreadsheet though.
chiendat
Dat
Fredericton, NB
2023 Mach-e GTPE
I tinkered with Forscan a bit on the splashscreen in the APIM module and noticed that the “welcome” screen isn’t there anymore. I have restored everything to before but it’s still off when I open the car door. Has anyone faced this before?
Ford Mustang Mach-E FORScan MME spreadsheet IMG_3046
Aulander
Italy
Open in Forscan the APIM settings, not the as-built line with the codes but the other one with the settings list. The option "Splash Screen" should be disabled, just enable it and save.
chiendat
Dat
Fredericton, NB
2023 Mach-e GTPE
The value of the Splash Screen on APIM is currently Mach-E GT.
It doesn’t show the Splash Screen when the car starts up but it does show when the car shuts down. Also the Splash Screen is there when I restart the car ?
Aulander
Italy
I would try to save a different value of the Splash Screen (don't remember which ones are listed) and then revert to Mach-E GT. Just to try.
chiendat
Dat
Fredericton, NB
2023 Mach-e GTPE
I tried to restore the factory backup but still not working. It might be just that the car not liking me.
rugedraw
Javier
Miami, FL
Auto Sales
Reload FORScan and when it is asks you if you want to load the existing profile, select no so that it does a fresh scan and try again.
50Mustang
Mach-E Premium
The amber side marker on the ‘21-‘23 MME Premiums and GTs are physically separate from the DRLs (as evidenced that the DRL stays on when the side marked is active). Not sure that the frequency of the white DRLs can be changed. ?‍♂?
What about 2024s? I did the same thing when I had my Bronco and could see if there's an amber on always DRL for the 2024 Mach-E
