- Lee
- Jul 16, 2021
- Wisconsin
- 2022 Mach-E Premium AWD
- Sci/Eng
FYI motor heat cannot be transferred into the cabin.
The coolant loop for the motors is not connected to the cabin/battery loop, so motor heat cannot be recovered to heat the cabin. It's physically impossible to transfer heat because the loops aren't connected, and there's no heat exchanger between them either. A lot of people have this misconception. Motor heat gets removed by the radiator to outside air only.
The only heat you can recover into the cabin comes from the battery, but is very minimal because lithium batteries do not really produce much heat unless they are DC charging. The only significant source of heat you can use is the HV heater.
Therefore you must turn on E-heat if you want any heat in the cabin. This is just how it's designed folks!
