Heater not working.
Smoothbond
England
Mach E AWD
Despite Ford's efforts to bat away the issues, Eheat is supposed to work as a cabin heater and it is failing on some cars. I have tested and proved this but still ford send me stupid emails with advice such as turn OFF eheat!
They are clowns.
The battery cooling system is supposed to provide heat when you turn off eheat. I have tested that and found it does not suceed certainly for me on an hours car use last week in altrincham weather, no heat produced whatsoever.
ford might as well give up on recycled heat from the battery except in summer weather which is when it wont be of any use in the cabin!
This is the same experience for me. My car is booked in at the dealers next Monday to look at this but if the consensus is the only way to get heat in the cabin is using e-heat (which completely decimates my range by the way) then I won't bother taking it in.
Yes, E-Heat is the only way to get a substantial amount of heat in the cabin. There is no heat pump and the amount of heat that can be scavenged from the drive components is negligible. By turning off the resistive heater (E-Heat), you're basically turning off the heat and then expecting to still get heat. It doesn't work that way. That's like turning off your oven and expecting that your food will still cook. Yes, it will greatly reduce your range. That's why you see so many people complain about the lack of a heat pump.
BMT1071
Glendale, AZ
21 MME SR RWD, 23 MME GTPE
EV Technical Trainer
The battery does not generate enough heat for the cabin, it's too efficient. That's why there's a 5 kW electric heating element in the coolant loop for the cabin heat. So yes, you must turn on E-heat if you want cabin heat, this is by design and is not a flaw. I'm sorry if you didn't realize you need to use the battery to heat the cabin on an EV.
Also FYI the powertrain coolant loop for the motors and inverters is completely separate and it is not possible to transfer heat between the battery/cabin and powertrain loops. This would not be useful in the winter anyway because of temp differences. Please be aware that EV's differ in their systems and are not all the same as Teslas. There is no heat pump in the Mach-E as others have mentioned.
Smoothbond
England
Mach E AWD
Thanks but apparently Ford engineers didn't realize the same because they've told me and others in this forum, (I have emails from them) to make sure E-Heat is turned off when attempting to heat the cabin. Not just that, I've been called 4 times by the Concierge service attempting to help troubleshoot the issue remotely with me in my car, them on the phone and they've asked me to do the same, turn off E-Heat. Plus my car was booked in at my dealership a month ago and it was there for a full day of diagnostics and the engineers were trying to get it to work without using E-heat. So either the documentation is really bad or a whole lot of people that should know better, don't.
Unfortunately I think it's mostly the latter. As someone with an engineering background who's familiar with the Mach-E's systems I can positively say you need to have E-heat on to get significant cabin heat. I have no idea why they would tell you that because it doesn't make any sense. I've read the service manual. The battery waste heat is not nearly enough to heat a cabin.
I just looked at the service manual for "blows cold" and unfortunately it appears to be copied from an ICE vehicle. It mentions the coolant temp needing to be above 150ºF (65ºC), I believe that is incorrect, I think the PTC heater would tend to produce coolant that's closer to 50ºC during normal operation. It appears that section should be updated in the service manual.
You should know that the heater is a PTC type which means it won't produce as much heat when it's already warm in the cabin. If the air coming out of the vents is at least 38ºC when controls are set to max temp automatic with E-heat ON, I don't think there's anything wrong. The air supplied will not get up to 60ºC like an ICE vehicle.
Smoothbond
England
Mach E AWD
Thanks for clarifying. I've canceled my 2nd diagnostics with my dealer
Ford engineers told you to turn off the heat when attempting to heat the cabin? Something is very wrong with that.
breeves002
St. Louis, MO
2021 Mach-E GT PE
I almost can’t believe the dealer and engineers would tell you to turn it off.
Just hit auto and adjust the temp. It will turn the PTC heater on as necessary. In Fords previous EVs there was no manual way to turn off the heater. The HVAC decided to turn it on and off automatically.
Smoothbond
England
Mach E AWD
E-heat, the
Please note, I was told to disable E-heat , Not turn off the heater . Turns out E-heat is the only source of heat in the car and they obviously thought otherwise . To be fair E-heat as described even in the cars dashboard is misleading . It is described as a ‘supplemental electrical heater used to warm the cabin before the car can make its own heat’ That’s not me paraphrasing that’s what it says when you click on the info for E-heat on the dashboard. If it’s supplemental and before the car can make it’s own heat , then I and others rightfully assumed at some point after switching on the car it will make its own heat. Turns out that’s bullocks .
Lord Polymath
Arkansas
2021 Sienna, '22 Mach-E Premium ER AWD (PWRPONY)
Computer nerd
E-heat, the
Where would this heat come from? Maybe you have to drive aggressively and make the batteries get hot before you can have heat? LOL
My guess is that maybe the car was originally supposed to have a heat pump or something? /shrug
E-heat is the heater. I can see how Ford's description can be confusing. Technically the car can "make its own heat" by scavenging waste heat from the HV battery and motors. But that heat will never be enough to warm a cold cabin. Ford's documentation should be clearer about that. At least you know now.
Guy
Guy
Canada
Premium AWD Long Range
I did the same test when temp was only cool outside, let's say 50F and could barely get any heat even with the E-Heat turned on. But now we are starting to get colder, 32F, E-Heat is very efficient and heat up the cabin real fast. It SEEMS that if the car does not sense cold temp outside, even with E-Heat on, you will not get much heating.
I'd say wait until it gets real cold outside to test it before taking it in to the dealer.
