Help-locked out
Jtodd64
Jeff
Texas
2023 Mach E
23 MME base model. Took the 12v battery out to replace it. Went to parts store to get a new one. While gone it started raining, so my wonderful wife closed the frunk so it wouldn’t get wet. Car is completely dead and locked up tight.
called a buddy at FD, they came out and tried double pull the inside latch. No luck.
they couldn’t reach the cable handle on the inside.
how much is a driver’s window?
NY_Cade69
Cade
Did you try the Frunk jumpers?
video here:
Fremont Kid
Colorado Springs, CO
Retired IT
Sorry Jeff, no idea. However, assuming the '23 frunks are the same as the '22s, explain to your wife that the frunk has a drain so precipitation can flow out.
I don’t have a power frunk
None of us have a power frunk from the factory. There is an electric frunk lid release though. The jumpers in the front bumper work only when the battery is gonzo dead or is not connected. 😁🐩
NY_Cade69
Cade
B177y
Olympic Peninsula, WA
'23 J2 MME Premium, '24 Lightning Pro ER, '20 Bolt
Ouch, I thought all frunk equipped Mach-Es had a power release...
Power release, yes, but you have to manually lift.
These jumpers only work when your battery is dead to release the latch, then you can lift the frunk, remove the trim and access the battery jump posts.
Double pulling the inside handle is a mechanical cable release...
