High-pitched "Electrical Whine"
machefan
NJ
Going to chime in, I do not have this whine from the driver display.
You do, you just can't hear it :)
Put it on day mode, full brightness and put your ear to the steering wheel with no background noise.
If not, recored it and post it here, you have yourself a winner if there is ZERO feedback.
Mike16
Michel
Canada, Quebec
Premium AWD ER Star White
I dont think you need to put the screen in day mode, in dark mode it does it too
If you have to put your ear to the steering wheel to hear the hum or whine, you’re making much ado about nothing.
RyZt
San Jose
Mach E4X
The idea is that some people are less sensitive, therefore they may need to do that to hear it. When a less sensitive person (e.g. one with high frequency hearing loss) cannot hear it or can only hear it when putting their ear near the steering wheel, a more sensitive person can hear it in normal seating position.
ARK
Los Angeles
'21 Premium SR AWD
Agreed, but the million dollar question so to speak is whether these differences in perceived volume are linked to differences with the amount of noise produced by any given screen or people’s sensitivity to this high-pitched sound.
eltonlin
NorCal
FE Gray
It's noticable when at a standstill and nothing on. That said, when driving it does get drowned out by road noise and wind noise. :/
SteelMach
2021 Mustang Mach-E
I can hear it from normal driving position, at speed, with the audio system on. Once you hear it, you can't unhear it. It's a constant presence. It's overwhelming.
Mirak
Kansas
Day Mode is so bright that one of first settings I’m going to configure is always Night Mode. Much more pleasant and perfectly visible in full daylight.
I’m also not going to drive with my ear pressed against the steering wheel until Ford enables Hands Free Driving.
Hopefully this won’t be an issue for me. I’ll know in two days.
Another_Engineer
Home
Mazda 3
I test drove one this past weekend and the electrical noise was very easy to hear from my driving position. I was curious if the noise was a one off issue, but then found this thread and see it’s fairly widespread. Other than this, I thought the car was really enjoyable to drive. Here’s to hoping that Ford is able to resolve the problem before I need to finalize my vehicle decision.
methorian
methorian
Roanoke, VA
IT Admin
So - On my drive into work this morning the whine was really getting to me. So I started fiddling with brightness again - this was the first time I'd did so while it was dark out. Turns out a bit less than "medium" brightness, while it's dark out, makes the whine almost completely go away for me!!!! It was like night and day. It is a pretty dim brightness setting, but I was happy to not hear it for once.
Unfortunately as I got to work and the sun was coming up the car was increasing the brightness to accommodate, and the whine came back. In daylight there is no brightness setting that makes it go away like that, so far as I've been able to test.
JellyBelly
Kris
MME RR FE
So even if you pick the darker color setting and not Auto, the brightness still increases due to daylight? Is yours set for darker screen color as a permanent setting or is at set to Auto?
