How long do you wait to charge after driving?
Up and Over
Massachusetts
2021 Mach E GT, Iconic Silver
Do you allow for 2-3 hours of battery cooling or do you start charging sooner?
Blue highway
Mach E Premium SR RWD
plugged into an L2 at home it doesn't really warm the battery enough to notice.
DCFC, I am on a trip and don't wait at all.
If you are worried about this, the cooling system for the battery is adequate so pls don't worry. When it's charged, its ready to go.
I plug right in. I only delay it if the battery might be very warm, which is rare.
Up and Over
Up and Over
Massachusetts
More curiosity than worry! Thanks for your reply!
axelheimer24
Axel
Buffalo, NY
22’ MME Premium ER eAWD Dark Matter Grey
The manual says to wait a couple hours, so I set the car to start charging at 10pm. Probably unnecessary, but that was an easy adjustment that costs me nothing. Most work days I’m home before 6pm, so 10pm is overkill most days.
JamieGeek
Southeastern Michigan
spareelectrons.wordpress.com
Plug in right away. If the battery is too warm it will cool it first. On L2 it doesn't really heat it up that much anyway.
Just this past weekend I plugged it in and immediately the vents opened up and the fans came on. After a minute or so it must have realized it wasn't that hot as the vents closed and fans stopped.
I charge whenever I need to. So if I need to plug in right after getting home, I do. I don't worry about it even though Ford says to wait.
For DCFC, we obviously plug in right away because it's during a road trip and time matters. Most of the videos I see suggest it's a GOOD thing to have the battery warmed up first. Although I'm sure if the weather is really hot that can probably work in reverse.
At home, I simply have the schedule set to start at 11pm, not because of temperature, but to be a "good citizen" and help the power grid by charging off-peak. My rates are the same 10c/kWh 24x7 regardless.
Teslaeata
Nottingham, England, UK
The same amount of time I wait to fill up my gas tank after driving.
Absolutely!
Wait 2 hours after driving before charging?
I can’t find that in manual, can anybody point me at this, pls?
Or is it another April fool I’ve fallen for ?‍♂
Drive a few hundred miles, pull onto charge station forecourt, sit for 2 hours and then put car on charge?
Really?
Surely that is utter nonsense!!
If that is the rule, nobody would ever buy an EV, what’s the point?
At home Big Red does have a few hours after driving because economy 7 [hours] don’t start until 1:30am but c30% of my charging is out on the road due to the distance I cover.
I've said this before, but I think the "cooling off period" is just a carbon copy from the Fusion or Cmax hybrid manuals. On those cars the battery actually gets pretty hot while driving and they had an abysmal air cooling system that didn't work very well, so you wouldn't want to charge those right when you got home if you can help it.
But on the Mach-E the battery is so big it barely gets warm while driving, so there's really no need to wait before charging unless you live in Arizona and it's 100+ degrees out. On my typical 30 mile commute the battery only warms up a couple degrees C, almost nothing.
