HVAC software update in FDRS
ProximusAl
UK
Mach-E - SR-AWD - Star White
I've just updated my HVAC, which cleared, but PSCM was still there, so I reapplied that, but it still doesn't clear :(
waltermorel
waltermorel
Walter
London
Mach E AWD ER
Humm, i will apply the update this afternoon and will let you know what happens on my side
Wonky_Donkey
Tony R
Norwich UK
2022 Mach-E RWD ER
I'm curious as to why @Wonky_Donkey doesn't have it showing.....unless he didn't apply it?
PSCM had bundled itself with some of the others, but it cleared down fine - which is wierd if you guys are stuck.
Here’s my current software version numbers and my FDRS activity report - can you check your PSCM and see if it’s at version LJ9C-14D003-BA as well?
Ford Mustang Mach-E HVAC software update in FDRS A1A836D0-B7C9-442E-90C5-4A889B3BED16
Ford Mustang Mach-E HVAC software update in FDRS E789107E-8DBE-410B-B85D-43E6EE98453E
ProximusAl
UK
No, mine is at LJ9C-14D003-AK. I wonder if its different if you have the bluecruise sensor or not. I dont...
ProximusAl
UK
Interesting in my History log, it shows under PSCM, "Vehicle Update" with the show button that shows nothing.
It did ask me to power the ignition about 4 times during the update?
Edit: All my actions appear under "Module Programming" for PSCM
Wonky_Donkey
Tony R
Norwich UK
2022 Mach-E RWD ER
Yeah it had me doing the hokey cokey with the ignition switch towards the end where it was updating this and that.
My neighbours think I’m nuts sat in the car for hours turning it on and off and on and off. ?
?Are they wrong?
waltermorel
waltermorel
Walter
London
Mach E AWD ER
Hi
Just done another update of PSCM. Still not clearing. Software P/N is the same LJ9C-14D003-AK
dsheib
Bridgewater, Massachusetts
Mach E Premium AWD SR, Ducati Multistrada 1200S
I ran many updates on Monday and Tuesday including the HVAC update that appeared Monday evening while I was doing them. Everything cleared fine except for the PSCM, I reran it on different days and after disconnecting the battery, still there. Mine is also on LJ9C-14D003-AK, the car is a 2021 Premium AWD SR. I just had a 2 day license so it will stay as it is until next time.
Ford Mustang Mach-E HVAC software update in FDRS Updates 3_22
ProximusAl
UK
Hi
Are you standard range or extended. I’m seeing possible logic that the SR models may be the issue (as they don’t have the driver monitor thingy)
waltermorel
waltermorel
Walter
London
Mach E AWD ER
AWD ER indeed
Wonky_Donkey
Tony R
Norwich UK
2022 Mach-E RWD ER
Well we've got a mix of Standard Range and Extended Range vehicles with the same software code. So maybe it's an RWD / AWD thing.
PSCM Software version scores so far:
LJ9C-14D003-AK on 3 x AWD models
LJ9C-14D003-BA on 1 x RWD model
I feel special ?
