HVB Replacement
4-Mustangs
Bruce
Chandler
2025 Mach-E
Has anyone had to replace their HVB pack?
if yes how old/miles?
The number of posts about battery replacements is so low that I can't even answer "Yes" to your question. Some have had battery packets replaced, under warranty.
This is basically a non-issue.
tbrumleve
Tom
Oregon, USA
Teslaeata
Nottingham, England, UK
But…….it still had been THE most asked question of me during my 5yrs+ of ownership to which I answer the “battery” will never fail! A battery consists of a battery of cells which are extremely unlikely to all fail altogether and can be changed in [pairs] of modules if any cell/s go bad.
Second most asked question……….what if you run out of charge to which I answer I never was so stupid to run out of fuel in an ICE so why would I allow an EV to run out of charge🙄🙄
4-Mustangs
Bruce
Chandler
2025 Mach-E
Yeah, that’s what I figured. I searched as well. But wanted to double check.
As you‘re probably aware there is a lot of disinformation on battery life expectancy.
i looked up info on 2012 Teslas (one of the oldest EV out there) and expected Life is 15 to 20 years 300k to 500k miles before battery performance is down 30%.
That seems high but better than the 7 to 10 years and <100k miles I’ve been hearing.
4-Mustangs
Bruce
Chandler
2025 Mach-E
There is a lot of UDaG (Unwarranted Doom and Gloom) about EV batteries and cells. The technology of Li-Ion batteries is stable and mature. 🤷‍♂️🐩
AKgrampy
Fairbanks, Alaska
I know one of the first Mach’s delivered to our local dealer had it whole battery pack swapped out. I do not know the “why” of it - only that it occurred and the car then left the dealership.
Blue highway
Oregon
Mach E Premium SR RWD
Consider the source... Whatever source says 7-10 years <100k miles battery replacement has an agenda... this is completely untethered from reality. You may consider whether they say other things that are completely untrue.
sbachman
Steven
Ann Arbor, MI
2021 MME Premier 4X
I was not aware of this! I came from a Chevy Volt and the only "viable" solution for a failed or failing pack was an entire rebuilt pack with used cells, for around $7K. That made me very sensitive about remaining battery pack warranty when I bought our 2021 MME.
Teslaeata
Aye, no real need to worry too much.
Whilst even replacing a pair of modules would not be that cheap, the chance this would ever be required, on my experience and what I’ve seen is very slim unless the battery’s been recklessly abused.
sbachman
Steven
Ann Arbor, MI
2021 MME Premier 4X
That's comforting, to an extent...
I'm a little cynical though, based on my Volt experience. Chevy salespeople initially implied that by the time the warranty ended, replacements HVBs would be reasonable, since battery price/performance and was advancing so quickly.
Then, as the Volt was being phased out and owners were having to abandon otherwise functional cars due to bad cells, GM came up with the Ultuim concept of plug-and-play technology-agnostic future-proof HVB modules for their post-Bolt EVs. We'll see how that works out in another 5 years or so...
Of course I hope that MME HVBs never fail, but I'm guessing some will. When that happens out-of-warranty, we'll find out how replaceable the cells are, and at what cost.
Not to be a Debbie Downer!
Blue highway
Oregon
Just like with hybrids, there will be the option of buying a used pack or module for a swap.
