- Steve
- Mar 23, 2021
- Bay Area, CA
- 2024 MME GT with Performance Upgrade, 1979 Fire-Am, 1972 K/5 Blazer
- Engineering
Being a Poodle of itchy phalanges, I decided I wanted the older ignition switch in my 2024 GT. So, I pulled the center screen and the instrument panel center trim panel. The switch is just held into the IP center trim panel by a pair of spring-loaded legs. Disconnect the wiring harness from the switch, squeeze the legs, and the switch slides out the outer face of the center trim panel. Reverse to install. The whole process took less than half an hour, a good portion of it trying to disconnect the pink connector from the center screen (paws too fat to depress the latch and not enough claw).
Before:
After:
While the old switch has the indicator lamp in it, the car does not illuminate it. Do any of the ForSCAN experts have any idea if this can be enabled in software?
If it can’t, I will probably swap the switches again.
Before:
After:
