Calgary
Mach-E
An additional update for anyone thinking of moving to Open Pilot (Comma 3X). Open Pilot performs much better in snow than BlueCruise. BlueCruise will disengage if there is snow covering the lines on the road, whereas Open Pilot is able to maintain operation and does a great job of driving with snow on the road and less-than-perfect conditions.
AjzRide
Alan
Houston
RR 2021 MME Premium RWD
Eng
i think it is dead. Give me an hour and I’ll try to get a new one up for you.
AjzRide
Alan
Houston
Eng
@Mv10858
Try this one. It will tell Comma you are an F150, but the I believe that is how we got CalgaryHero and EV_Vida working as well.
installer.comma.ai/tinkerborg/ford-comfort
edit: F150 and MachE use the same IPMA.
Mv10858
Matt
Iowa
2021 Mustang Mach E GT
Finance
@Mv10858
Thanks got it to download I don’t have a clue why I can’t get it off the main screen. I must not be smart enough!
Ford Mustang Mach-E Installing Comma.ai / OpenPilot (BlueCruise alternative) IMG_6559
AjzRide
Alan
Houston
Eng
Should switch when you go into Drive.
Calgary
Mach-E
The rumor is the Mach-E is waiting for Comma to do injection testing which is a step to get the Mach-E on the main OpenPilot release ... and eventually full support (fingers crossed). The ADAS is great, but the experimental FSD features are not great - it will still rip through most stoplights and many stop signs.
AjzRide
Alan
Houston
Eng
yes, but is not really a MachE specific issue, that has more to do with the experimental nature of that model. It’s not really any better on a 100% verified car. There is a reason you have to go through 3 toggles and two “I acknowledge this is experimental” agreements to turn those features on.
RyanSD
RyanSD
Ryan
2021 Ford MME AWD EXT, 2013 Yamaha Stryker
IT Systems Architect
After running OpenPilot for a few weeks, I've moved over to a popular fork called SunnyPilot and was able to resolve the fingerprint issue by modifying some of the Panda code in uds.py and adding the Mach-E ECU values. Vehicle now being recognized properly.
Ford Mustang Mach-E Installing Comma.ai / OpenPilot (BlueCruise alternative) 1698990727330
I maintain my own personal GitHub fork for personal usage and highly recommend, to anyone interested, do the same.
Ford Mustang Mach-E Installing Comma.ai / OpenPilot (BlueCruise alternative) 1698990804291
briankwest
McAlester, OK
2023 F-150 Lighting, 2023 Mustang Mach-e GTPE
As of 0.9.2, Comma.ai began to support Ford vehicles. Their latest release, 0.9.4, is quite impressive.
Went ahead and put in an order for the Comma C3X and the needed Ford Q4 Harness .
Since our IPMA is located in the trunk area, a long 3.1 USB-C extension is required. I picked out this one, as it seems to meet all the specs.
I will be documenting and taking photographs to the best of my ability so that people can hopefully learn and not repeat any mistakes that I make.
Just ordered two Comma 3x's one for my Mach-e and one for my Lightning... Do the USB cables and ethernet need to be 12ft? seems the ones linked from the guide can't be shipped to my address.
AjzRide
Alan
Houston
Eng
The lightening needs an 8’ or 10’. The Mach E you can use a 10‘ and a 6’ extension cables.
Mv10858
Matt
Iowa
Finance
You are welcome to check it out: installer.comma.ai/SurferSD/ford-dev-c3 . I warn you that it's a development build and I update the code frequently to test/trial.
Trying your build unable to get out of dash cam mode says car unrecognized… any tips?
