- Ford
- May 10, 2021
- Dearborn, MI
- Mach-E
Hi there, everyone! The EV Navigation system is designed to make you aware of points of interest like school zones, border crossings etc. However, sometimes these messages are not necessary if for instance you live next to a school or pass a number of school zones on your drive each day. If you would like to further personalize the messaging, you can adjust by doing the following: In the navigation window selected from your user menu you will see a wrench and screwdriver symbol in the lower left hand corner, select that. Then you will see a number of options pop up, and in the lower right hand corner is a settings button which you will select. There are a number of things you can change, but you want to select notifications. There will be toggles you can use to adjust the messaging in the navigation system. Hope this helps!
