Is This Normal??
azerik
Chandler/Flagstaff, AZ
DevSecNetOps, General PITA
They probably just installed the wrong battery. No biggie.
There is it folks we found the one that slipped through on the production line for this season.
Jimbo
Jimbo
US
Premium 4X
Regarding battery range: We had an unusual experience lately. We left town, on a trip with my ICE car and left the MME in the temp controlled garage for 4 days. When we came home the battery state of charge was about 85%. We made on short trip, with the MME, maybe 10 miles, and when we got home the battery was down to 30%. Seems odd to drop from the 80's to 30' after one short trip in temporate weather.
Has anybody else had the same experience? Does non use for a few days drastically alter range?
I've only had this once (battery dropped from ~80% to ~40% after only ~5miles), a couple months ago, but:
*Car had been soaking in below zero temps all day
*LVB was on its last legs
*I had that update that wreacked havoc on charging (pump always running, HVB loses charge while charging, terrible charge speed estimates, etc)
I presumed all that combined led to the BMS not knowing the actual charge state, and haven't had an instance since
65MustangBoy
Les
Indiana
65 Mustang, 2023 Mach E Premium
On a 75-degree day I can go 220 miles with a STANDARD RANGE battery. Has nothing to do with the GOM, that is based on actual miles driven. I will admit I was getting very anxious the last 15 miles to my destination which was a charging station, so we had switched off the AC.
mateo
Chicago
2022 MME GT
I have a GT and a GTPE and they get equivalent range.
At highway speeds in 70F weather, I get around 250 miles. Same trip in freezing winter, I get around 180.
All other situations I don't care about because I charge nightly to 80%-90% depending on season.
67 Stang Convertible
Rich
Georgia, USA
Physician
I thought “wrong battery” season was over…
So did I; but the responses are always entertaining.
OP, completely normal; not as dramatic with an ICE Vehicle, but same principle. Cold sucks, Move South :)
Mnath
Oakland, CA
Mustang Mach E
Unfortunately, you're going to get more replies about not searching and forum etiquette from the old heads here then actual answers.
The answer is, it's totally normal. First off, you will never get 300+ miles. Ever. Count on between 200-250. When it drops below freezing, you're going to get much less. I had a AWD Select for about 2 years, and I never got more than 100-110 miles of range when it was below freezing. Keep in mind, I never drove it until it died, so there's a chance I could have squeezed out more, but who wants to take that chance. There are numerous threads here about preconditioning, and other ways to extend your range. That said, you aren't going to get 300+, so don't ever count on that.
I recently upgraded to a Extended Range Premium, mainly because the range of my Select didn't fit my driving needs. I made a similar mistake to what you did. I assumed I would get 215 miles of range, per the rating. I read posts where people said Ford underestimated their range. I believed people when they said "oh yeah I get 250 miles of range in that exact vehicle". All mistakes on my part. It's been an education for sure.
I get over 300 on my 2023 Prem extended battery every time I charge to 100% (which is not often, only before a road trip) Sometimes it's been 312, sometimes it's been 319.
sparkout
Cliff
2021 Mach E 4X Premium
Only 210 miles on a full charge! I got the extended battery and was expecting 300+ on a full charge. Should this be taken to service?
Don't worry, that's very common. When the temp gets to be 80+ available miles go way up.
lwilliams0514
Lashawn
Gardena, CA
2021 Ford Mustang Mach E Premium RWD
Finance Manager
I noticed after my last update my range dropped too. But it is slowly coming back to the level I expected. Give it some time and perhaps weather is affecting it.
ThatGuyLando
Iowa
22 CR1
Software Developer
Yeah.. you're likely never gonna get the 300+ miles. Those EPA ratings are weird and automakers take advantage of the fact that they aren't the ones who said what it should be.
Depending on what car vs reality numbers you look at people will either say "they are a bunch of scamming pricks" or blindly defend it like "oh you didn't drive at exactly 20 MPH and it was either too hot, or too cold, you were going against the wind, or the moon was too far away".
That number is supposed to adjust to your driving style, but Ford seems to sometimes push updates that "resets" it. So my advice is don't rely on it, just go by percentage and for long trips cut out a good 15-25% range while planning, in between charges just to be safe.
KidGalahad
Oklahoma
2023 Ford Mustang Mach-E Premium
@Prusucks my advice to you is charge at home every night, just like you do with your cell phone. For road trips, try to charge every 150 miles or so. You can use the Ford nav to plan your trip out, and it will find chargers for you. Also, keep in mind that temperature and speed dramatically affect your range. An ICE vehicle does better on highway and worse in town; our vehicles are exactly the opposite. Driving in sub 32/0 temps dramatically lowers the range. Highway driving lowers it as well.
Another thing I like to do on road trips is keep an eye on the current range, and miles to destination:
Ford Mustang Mach-E Is This Normal?? IMG_0441
According to that, I should have 52 miles of range when I reach my destination. However, due to temp and speed, that estimate was down to 39 miles by the time I got home. So, doing some calculations when you’re driving can help determine if you need to adjust your charging strategy.
zvez
chris
ga
Okay, I'm sorry, but I can not stop laughing over this. Seriously made my day.
funnily enough when I first got my 21 rwd standard range I was surprised I was consistently getting 4.0/mi/kwh so I was thinking that they put an extended range in by mistake and didn't charge me for it! ;) Now if only I could come close to 4.0 on my gt!
Space_Pony
Indiana
2026 Premium Mach-E eawd
Why would an extended range be more efficient. It's heavier so I would think it would get less miles/kwh. Am I missing something.
zvez
chris
ga
not saying it's more efficient but extended is 91 kw vs 70kw so would expect range to be longer on extended.
