markboris
- Mark
- Nov 13, 2019
- Sonora, CA
- Currently: '20 Shelby GT500 FPB '24 Mach-E GTP GGM
- Retired
The battery in the keyfob can be dead or not even in the fob and the car will still recognize the fob and start. It has been this way in every Ford I have owned. There is usually a spot in the console storage bin to put the fob and it will start the car. You can try this if you want with the Mach-E. Remove the battery from your fob and put it in the area in the console storage bin that looks like it would hold the fob and the car will start up.Yes. Many have had issues like this at one time or another. If we choose to rely on an electronic key then we are also choosing to accept the possibility that software might not work as expected every single time. Its not really that different with the key fob because the battery can die and then the fob won't allow access either. In that case then the door pillar code or FordPass is your path to entry and then the dead fob can start the car with the console holster.
A real hard key is almost 100% foolproof (provided you don't lose it).
A key fob (without a hard key) is very reliable but even that can fail if the battery dies.
