L button on shifter
ajmartineau
Washington
2021 Mach-E
On the Bolt, it is a way to engage one-pedal driving with no effect on throttle mapping.
opennetus
Ford Fusion
Does anyone know if the “L” mode turns on the brake light while you are slowing down with one pedal driving? My main concern with relying heavily on automated regen braking is that cars behind me will not be immediately aware I am slowing down.
portlandg
grahame
Dorset UK
Black RWD ER and loving it
Cabinet maker
Then they shouldn't be that close to you ? Seriously though, I think they do above a certain level of strength. If you use Adaptive Cruise control, when that brakes to slow you down your brake lights do come on. But it might be set by local laws[/QUOTE]
JamieGeek
Southeastern Michigan
spareelectrons.wordpress.com
On the Bolt the brake light comes on when decelerating but when the car stops the brake light goes out.
On the Mach-E Ford has shown on the display that there is a specific 1-Pedal mode you turn on for that behavior. It is likely that they will make the "L" just drive more like driving an automatic in Low (e.g. more regen when coasting and a little bit harder acceleration).
Furthermore Ford has said that in 1-pedal mode when you come to a complete stop the car will engage the friction brakes to hold you there (the Bolt doesn't--the owner's manual instructs the driver to press the brake pedal). Thus it is likely that the Mach-E will also keep the brake lights on when stopped as well.
Stickboy46
Kansas
2020 Tesla Model 3 AWD LR
At least on the Tesla's, as soon as regen kicks in, the brake lights come on. I would think that would be a requirement on the MME also.
zhackwyatt
My intuition (which I think is awesome and reliable) is that you are correct.
GregM
Audi A3, Tahoe, Mustang Mach E Premium (on order)
Communications/Marketing
I had the same question - what is the L for...ha
I would think the L on a BEV is different than in a PHEV...right?
Not sure how the MME will behave when in max regen mode.....however, this is no different than when letting off the throttle in a manual transmission vehicle or heavy truck. The driver behind you will know you are slowing down. We get pretty good at comparing relative speeds with other vehicles on the road and recognizing fairly quickly when that delta changes even a little bit.
mattbostonmache
mattbostonmache
Matt
Newton, MA
Rav4
Any idea what the buttons are in front of the parking brake (to the front right of the shifter dial)?
Ford Mustang Mach-E L button on shifter 1595981278419
Daniel M
Daniel
Southern CA
21 Mustang Mach E, 2020 Ford Edge
One of them is for the auto parallel park option. Not sure of the other yet.
Wardmoranfamily
Stephanie
Duncan bc
2021 mustang Mach e
Administration
Question: does your gear shifter spin all the way in a circle and counter clockwise as well? Mine spins round and round even after its in D
My car went into the shop for 9’weeks—long story. And I swear the 8 days I had it before that it didn’t spin round and round!
