Lost connectivity settings after 5.1.1, can't EA charge
DaveQ
Fernandina Beach, FL
Mach-E4X, HR-V, Insight, Maserati Levante S
Limping home, so disappointed that I cannot charge at reduced rate at EA because connectivity settings are gone. What's going on?
Ford Mustang Mach-E Lost connectivity settings after 5.1.1, can't EA charge PXL_20230824_192952852
Ford Mustang Mach-E Lost connectivity settings after 5.1.1, can't EA charge PXL_20230824_193003755
Vulnox
Livonia, MI
Any chance you tried the volume down/seek forward hold on the steering wheel to restart Sync? Not sure it would resolve the issue, but may be worth a shot. I think it just restarts the APIM and some of the connectivity items are through the... TCU? I am rusty on that front, knew it well diagnosing connection issues when I first got my 2021 F-150, hopefully someone else can clarify. But either way shouldn't hurt to try.
hybrid2bev
2026 Rally
So you couldn’t activate the charger using the Electrify America app? Or via the FordPass app to use free kW credits or BOCN payment method?
DaveQ
DaveQ
The charger would not connect to the car and the charger defaulted to $0.48 and asked for a credit card. Ford pass app shows error message to enable connected services, but it's missing in vehicle.
Ford Mustang Mach-E Lost connectivity settings after 5.1.1, can't EA charge Screenshot_20230824-193401
kodiakng
2023 Cyber Orange 4X Mach-E
if you really need juice i would just pay by credit card at the EA station and fix the connectivity and app settings later.
hybrid2bev
2026 Rally
To be clear. You activated the charger first via the EA app and then plugged in? Or were you trying to Plug&Charge?
DaveQ
DaveQ
Sorry, plug and charge.
hybrid2bev
2026 Rally
Ah, okay that makes sense.
Activate first via the EA App (or tap via your membership card in your phone’s wallet) and then plug in. That’s the trick to get the pass+ rates.
Logal727
C
Yep, this update turned off some connectivity settings, just happened to me as well, were you able to turn everything back on yet?
I’m assuming I’ll be able to once I get the connectivity menu to come back up
BK2EV
21 MachE AWD Premium ER, 2015 Challenger Hellcat
DaveQ
We are in the same boat as you.
We got 5.1.1 last thursday 9/28
Post OTA:
Noticed charging no longer appearing in FordPass app.
The last charge log entry was from early AM last thursday prior to getting 5.1.1
Departure times icon (square) is missing totally
All vehicle connectivity was turned off
Since the issues appeared we have:
Cleared Fordpass app cache & data, signed back in - No change in symptoms
Uninstalled Fordpass, rebooted phone (S23), reinstalled app and signed in - No change in symptoms
Turned all desired vehicle connectivity on - no change in symptoms
Edited charge location to change name and save - no change in symptoms
Deleted saved charge location (home) and recreated - no change in symptoms
Through the Fordpass App if I click the Connected Services icon I get a "Oops were sorry an error has occurred processing your request. Please try again."
Something is going on......
2021 Premium Extended
BK2EV
kdukart
Kyle
Minneapolis, MN
Chrysler Pac Hybrid, Mazda CX-5, Suburu Outback
Hello all. Having the same issue on my 2021. Updated to 5.1.1 on 9/28 and now connectivity not working. No options on the menu.
what to do?
Itsssmeee
Bay Area
2023 Standard Range
DaveQ
Post OTA:
BK2EV
this happened to our mache as well. The app notified/claims the car is updated on 09/22 to 5.1.1 then on 09/24, the car is no longer reporting to ford pass.
when I check the software status in the car 09/26, it says 5.1.1 update is not completed.
Going to take the car to dealer this sat.
DevSecNetOps, General PITA
This sjit better work for me tomorrow . I’m 200
Miles away and on a schedule.
hybrid2bev
2026 Rally
DaveQ
Post OTA:
BK2EV
Did you try pulling the TCU fuse to reset the module?
https://www.macheforum.com/site/thr...ped-updating-info-on-my-car.27620/post-631955
