tuminatr
Saint Paul,MN
2021 MME GTPE
sales
I have seen a few tesla fire videos that doesn't look too bad
Davedough
West BYGOD Virginia
Mach E GTPE , Explorer ST
Federal IT Sales Engineer
Shayne
Northern Ontario Canada
2021 MME4x Prem
Mine hasn't moved since I got it. It still hangs in my garage, unused
It stores prefect under the MDF adjustable back floor board and has stayed in place there since the first month of falling off. What exactly do I need this for? ;) It would flap around sometimes when windows were down a certain way also. Could see it in the mirror. Tried to make it more aero dynamic by tipping it down and it helped but did not fix it. Fits well stored away and keeping it almost new for the next owner.
Davedough
West BYGOD Virginia
yeah, I thought about putting mine there but I worry the sub I installed will make it flap under there
dbsb3233
TimCO
Colorado, USA
Where'd the info come from that it was a battery puncture? Everything linked on this thread just says "cause unknown".
Exactly. I don't see that part actually reported anywhere. Looks more like like something inside caught fire. Could just be a cigarette dropped in a bag or something for all we know.
If the battery pack had punctured from underneath, we'd likely see signs of burnt pavement, burnt paint, and melted tires.
Jooced
San Diego, CA
Mach-E GT 2023
Looking at the picture, I'm starting to think this is a new guerrilla marketing campaign by Chevy or Subaru.
dbsb3233
TimCO
Colorado, USA
Unless a report appears that shows the battery pack was actually punctured from debris, the forum administrator should probably change the title of the thread.
Hammered
SE US
2022 PB F150, MME GTPE
Pretty much happened once to every EV it seems. The last one I remember was this:
https://www.kiaevforums.com/threads/weak-undercarriage-or-bad-luck-punctured-battery.4985/
Wasn't a fire but could have easily caused one. Punctured batteries become flammable due to shorts + thermal runaway.
Yes, pouch cells in particular are very susceptible to thermal runaway events. The 4680 and other aluminum shelled cell architectures are much safer options as the event stays within the confines of the cell itself. Pouch cells are the worst design.
Bmr4MachE
Atlanta
Mach E Premium AWD Ext ordered Feb 2022
That is some horrible press. Dang.
Electric Ford Mustang EV vehicle battery was punctured from freeway debris and caused a fire. CCFD is having a hard time putting it out. It keeps reigniting. They been onscene for about 2 hours now.
OP, are you able to get an update from that private first responders Facebook group you are part of? Were the firefighters sure the pack was punctured?
Hammered
SE US
I wonder what they thought when they opened the frunk...likely "Aw crap, it's a BEV..."
No, they opened the frunk to kill both batteries. This is SOP in dealing with fires. Firefighters / first responders have a wealth of info sheets about this. It's not an accident that when you google a vehicle one of the first things you come across is its disconnect points. In the chevy bolt there are very clear labels under the hood that say "cut here" to disable both of the batteries. -- there's 2 of them.
The second link sent me here... showing how to access and disable the HVB and the 12v battery ground is clearly visible once that panel is removed. First responders have their own info, but some smaller departments might have to literally google it.
https://elvsolutions.org/wp-content/uploads/2020/12/Mach-E-Battery-Removal-Guide-11-23-20.pdf
kltye
Chicago
IB MME Premium RWD
you don't apply water to a lithium battery fire that's like pouring gas on a fire.
The protocol is to actually douse it with a ton of water:
https://arstechnica.com/cars/2021/1...ivers-water-directly-to-blazing-ev-batteries/
The lithium in batteries isn't pure lithium, so the reaction with water isn't very energetic. At least compared to the rest of the short-circuit...
Also, it's in the first responders' guide: https://www.fleet.ford.com/content/dam/aem_fleet/en_us/fleet/showroom/resources/2021_Mach-E_ERG.pdf
Ford Mustang Mach-E Mach-E catches fire on highway 1674598839986
