Mach-E Dashcam and Sentry Mode Updates
MTNestr
Paul
NW Ohio
2021 Grabber Blue FE MME - traded for - 2025 Velocity Blue Mach-E GT
I’m just waiting till I take delivery this weekend to order a dash cam. I want to make sure that it‘s not to difficult to install in the Mach-E.
highland58
IT Solutions Architect
Has anyone used the IROAD OBD-II cable in a Mach-E yet? I just ordered the Thinkware U1000 with that cable, hope it works ok. They have different versions for electric cars and ICE cars.
darren
Subaru Outback, Mach-E
The main reason to use the OBD port is to avoid splicing into the cars wiring system. You can easily remove the connector to return the car to factory condition.
I have a response on the other thread:
https://www.macheforum.com/site/threads/dash-cams.3661/post-115475
You don't have to splice wire, just replace the 12 V fuse with the special adapter.
I have installed DashCam on 2 of my cars (MME not yet). One of them is always on, and the other will turn off when I turn off the car.
MTNestr
Paul
NW Ohio
I’m looking at the same 4K Dash Cam. Once you’ve installed the U1000 please post a picture and if you had any issues with the OBD And how easy it was the run/hide the cables. I was going to order the U1000 with the OBD and also the hardwire kit just in case I couldn’t figure out the OBD. My second option was the BlackVue 900X. Did you go with the 2 channel version?
MJMachForum
2019 Blue Flex, 2021 Grabber Blue Mustang Mach E
The ford accessory site offers other Thinkware webcams and those kits have the OBD adapter included. I suspect The OBD adapter is compatible. Why would Ford offer accessories that wound't work with the Mach E.
https://accessories.ford.com/vehicles/mustang-mach-e/2021.html?cat=391
highland58
Does it say compatible with Mach-E?
The IROAD OBD-II Cable comes in two versions: a "Non-Electric/Hybrid" option for conventional gasoline/hybrid engines, and a "Electric" option for true electric vehicles (ie. gets all of its power from electrical sources).
MJMachForum
I provided a link to the Ford accessory site filtered on the Mach E and dash cams. So according to Ford the dash cams in the link are compatible. Beyond that I don't have any further details. You'll have to reach out to Ford to see which version of the OBD connecter they are including in those kits.
UPDATE: I saw your mention of IROD adapters. Thinkware provides its own adapter the HWK-TW01 for OBD connections. There is no mention on Thinkware's site about EV vs. ICE installations. Correction: Thinkware says the HWK-TW01 is not EV compatible. I suspect that is the cable provided in the Ford kits. May want to reach out to Thinkware\Ford on compatibility.
MTNestr
Paul
NW Ohio
MTNestr
Paul
NW Ohio
Does anyone know if there are front facing sensors on the rear view mirror that would determine where not to place the dash cam?
ajmartineau
Washington
2021 Mach-E
Thanks. I emailed someone else and another person responded from the executive office. I have a call with them tomorrow.
Any update?
MTNestr
Paul
NW Ohio
When you say OBDII adapter, does that prevent the port from being used? I hope to keep a Bluetooth OBDII adapter always plugged in while driving for data logging on my phone, so that'd bummer if I can't have both that and the Ford dashcam while they develop a built-in solution.
What is the adapter you’re using for data logging? What data does it log?
