Mach E energy consumption
Florida7382
Mustang
Now that we know the usable battery figures -> has anyone updated their math on what the energy consumption of the MEE would be?
ABRP refers to 378 wh/mi (245 wh/km) for the ER/AWD and I’m wondering if that’s still the right figure.
JamieGeek
Southeastern Michigan
spareelectrons.wordpress.com
Do the math: 88kWh usable and 300 miles of range 88,000/300 = 293 wh/mi (ok ER RWD).
For the ER AWD range of 270 miles: 88,000/270 = 325 wh/mile
exactly, although ABRP uses a little less efficient number for highway speed driving
Raymondjram
Raymond
Bayamon
I prefer to use the inverse: miles or kilometers per kWh which is easier to understand and compare with miles per gallon for the gas engine cars. The average value is about 3 miles per kWh, so if the Mach-E can meet or pass this number, it is considered efficient, and the higher the better. If the 98 kWh battery can run for 300 miles, that is better than 3 miles per kWh (actually 3.4). Then if your EVSE can report how many kWh it has charged the battery, then by multiplying by that number gives you the range. Simple!
Counting watts per mile is like counting quarts or liters of gasoline per mile, and is quite confusing.
Florida7382
Mustang
I now noticed the ABRP 378 wh/mi is reference for highway speeds @65mi/h, which would be 16% increase to the calculated average consumption. Does that sound realistic? Just trying to figure out where my MEE would realistically take me in different scenarios. ABRP also has the speed limit %-functionality which is quite nice, considering I don’t usually drive 65 at highways on a Mustang...
16% less at 65 MPH. That's fairly significant. And that's only at 65. In the east that may be more normal highway speed, but further west 75 is more common. Probably well over 400 then.
I should have read yours first before replying. Duplicated some of it. :)
I've heard some say as much as 30% cut in mileage at high speed, but that's probably at 75+. Seems like some BEVs are more aerodynamic than others, where 65 may not be too bad. Hoping the Mach-e is that way, as Mustangs should be designed for speed. But I'd be prepared for 30% loss at 75 just in case.
ajmartineau
Washington
2021 Mach-E
Here's an interesting chart that is a great visualization of how speed and temperature affect the range of a BEV.
Ford Mustang Mach-E Mach E energy consumption InkedInkedBoltRangeVsTempTesla_LI
This is for a pre-2020 Bolt with an EPA range of 238, 3.9kWh/mile.
Florida7382
Mustang
Very good, thank you!
ajmartineau
Washington
2021 Mach-E
Hi Lyt,
I think you'll be safe with your calculations.
My real-world experience.
I rarely ever/never get the actual EPA range on either of my cars. In the summer I get an extra .5 - 1 mi/kWh and in the winter I lose .5-1 mi/kWh (the -mi/kWh is when I use the heater).
EVer
San Diego, CA
Hi Lyt,
I rarely ever/never get the actual EPA range on either of my cars. In the summer I get an extra .5 - 1 kWh/mile and in the winter I lose .5-1 kWh/mile (the -1kWh/mile is when I use the heater).
I think you got that backwards. Running cabin heat will decrease your efficiency, not increase it.
ab13
Rav4 Hybrid
What's not known is the top end of charging. Will it be necessary to not charge to 100%, will there be regenerative braking with a full charge. This information is yet to be determined.
waldo1949
Walter
michigan
Infinite Blue mach e 4x
On premium awd, about 3 miles/kwh.
Based on owning two Volts, range varies a lot with driving condition:temp, speed, rain, snow on the ground, stop and go vs no braking.
It liked country roads, with gentle hills at about 70 degrees and 45mph best and exceeded advertised range then.
At expressway speeds, in the cold, with rain or snow to push through, range dropped a lot.
The Volt varied from 2mi/kwh to 4 based on conditions. Overall, driving in Michigan over a year’s worth of weather changes, ranged averaged exactly what GM predicted, but varied a lot from day to day.
