EVmodeler
Doug
SW Virginia
Mach-E AWD ER IB Job 1
Engr Prof emeritus
I put together a pretty basic acceleration model and was able to match the Ford target of 0-60 mph with 1 ft roll out by adjusting the test mass just slightly. See attached. The modeling of a higher performance GT model gets a bit tricky due to traction and traction control. Has the curb weight of the GT been published?
Edit: I have added the calculations for the RWD here
EVmodeler
EVmodeler
Doug
SW Virginia
Engr Prof emeritus
When cars get into some reviewer/magazine hands, will be interesting to see if the 13.5 s 1/4 mile time prediction matches up with testing.
zhackwyatt
This sentence is interesting:
EPA test mass is curb + 300 lb = 2 (circa 1975) people,
So this needs to be updated to EPA test mass is curb + 400 lb = 2 (circa 2020) people,
Agreed. But EPA still uses 300 lb.
Yeah, airlines use 180 lbs for summer passengers and 185 for winter passengers. Plus all bags weigh 25 lbs, so the numbers used here do not surprise me at all.
Reactions: Nak
zhackwyatt
When I first looked at the data I didn't realize I was looking at Males only.
Ford Mustang Mach-E Mach-E Extended Range -- acceleration modeling 1606872421279
So if you average the data between Males and Females, it's actually 182. So the airlines are pretty close.
Do they change that to flights to American Samoa?
sockmeister
Pennsylvania
2023 Mach-E GTPE
SW Engineer
That's a great effort to piece this together from the scattered info out there. Nice job, and very interesting.
Can't wait to see the real world tests. Especially with better tires.
Shayne
Northern Ontario Canada
2021 MME4x Prem
We have no females up here; too cold. Waiting to see how close the cals are.
Awesome report! The acceleration chart is presented in a couple of the Mach E webinars. One is here in https://www.macheforum.com/site/threads/mach-e-web-series-part-4-performance-and-charging.1578/
Ford Mustang Mach-E Mach-E Extended Range -- acceleration modeling Screen Shot 2020-12-02 at 10.22.43 AM
Shayne
2021 MME4x Prem
Predicted 13.46 sec 1/4 mile finishing at a bit over 100 mph is respectable. About 10 mph left in the bag? Your prediction on the passing band looks good also; they may not see you go by. They later I will test.
