Mach-E Extended Range Battery buffers and DCFC limits
phidauex
Colorado
Renewable Energy Engineer
Thanks for your graphs, I like seeing your work.
Regarding the battery buffer, we probably won't know until we start seeing detailed cell voltages, but I had assumed that the allowable range was probably more like 2% to 92% of chemical SOC, rather than 8% to 98%. I design grid-scale storage, and we tend to run buffers biased toward the low SOC range because the higher SOC range is more sensitive to degradation (hours above 90% is one of the key degradation metrics we use).
I didn't realize that was referring to the 10kWh capacity buffer -- I thought it was about the battery's current limitations assuming it's locked at 88kwh.
So in the end, you're saying it's unlikely much additional capacity will be unlocked? Why do other manufacturers have much smaller buffers for the same technology?
You can set any buffer you want, but the larger the buffer, the lower the degradation. Your minimum buffer is probably something like 2-3% if you want to avoid constant voltage charging at the very top end. For systems I work on with 25 year service lives, we might start with upwards of 40% buffer, gradually reducing over time.
So Ford's large buffer is probably related to a conservative view on warranties. The narrower they set the buffer, the more 8 year battery warranties they will pay out. Some manufacturers are way out over their skis on warranty obligations and there will be rude awakenings in the next 5-10 years...
RonTCat
Ron
Mach-E wannabuy
The next move will likely be to something that either doubles the series array to 188 individual cells (94S -> 188S), or takes the current batteries and series two of those. You then go to what will be referred to nominally as "800V" charging. Maybe someone who knows can tell us which way things are leaning.
EVmodeler
EVmodeler
Doug
SW Virginia
Mach-E AWD ER IB Job 1
Engr Prof emeritus
In a vehicle application (high power, dynamic loads), the voltage cliff at the bottom end probably requires the bigger buffer. Also, higher discharge power at lower voltage requires higher current. In the vehicle, the approach to high SOC occurs during charging and/or regen, so the charge rate can be controlled, and (probably) requires less buffer. Charge power limits do not change driveabilty as much as discharge power limits. All of these are just my (hopefully well informed) estimates from some experience.
And - why Ford says every day charge to 80 or 90 % (indicated), to avoid time at high voltage which degrades battery materials.
800v charging is already here. That’s how the Taycan gets 270kW.
EVmodeler
EVmodeler
Doug
SW Virginia
Engr Prof emeritus
Yes - to get higher charge rates with 400 A current limit (SAE DCFC standard) requires higher voltage batteries; the Audi, and iD4 I think, have ~ 400 V nominal battery packs - 110 cells in series? Rather than 94S / 342 V (ER) or 96S / 350 V (SR) nominal in the MME. The Taycan has 198 cells in series for about 720 V nominal. From the EPA cert data document:
Ford Mustang Mach-E Mach-E Extended Range Battery buffers and DCFC limits 1613842314651
The VW group seems to be the only one exceeding max DC voltage of ~ 400 - 425V so far.
There are good (human) safety reasons and common electrical component rating reasons to stay with ~ 350 V nominal.
Edit - correction, Audi probably uses 108S. There is a lot of mixing of max vs nominal voltage for battery packs by manufactures. From the EPA cert data: (4 modules in parallel, 9 modules in series, 12 60 Ah cells in series per module)
Ford Mustang Mach-E Mach-E Extended Range Battery buffers and DCFC limits 1613843335425
RonTCat
Ron
Mach-E wannabuy
Yes - to get higher charge rates with 400 A current limit (SAE DCFC standard) requires higher voltage batteries; the Audi, and iD4 I think, have ~ 400 V nominal battery packs - 110 cells in series? Rather than 94S / 342 V nominal in the MME. The Taycan has 198 cells in series for about 720 V nominal. From the EPA cert data document:
Thanks. Agree with going over present nominal... most standard motor drive power supplies likely won't do more than 500VDC. Once over that, you are getting into low volume "custom" equipment, which costs $$$$. I'm sure it's why the Taycan price is what it is :rolleyes:.
EV Lab
San Jose CA
IB MME 4XE, Ford F-150, Honda Civic EV conversion
Electrical Engineer
It's really just Tesla that does this, and they also don't design the car for 10 years+ lifespan, which they've openly stated.
phidauex
Colorado
Thanks, that makes sense, if you aren’t spending much time at high soc, but want full power at the low end, you might leave more buffer in the low end of the range. I’m probably more degradation sensitive in grid applications too, trying to get 20 years of 300+ equivalent cycles per year (at very low c rates, thankfully).
Alex on Autos has a video where he is on the highway at very low soc, and there is no indication of turtle mode so clearly it wasn’t in heavy current limiting yet, which supports your theory.
EV Lab
San Jose CA
Electrical Engineer
More and more vendors are offering 800V powertrain equipment. From my experience with an EV OEM, the other components such as DC-DC, EPS, HVAC, etc were hard to find in 800V. Plus the powertrain still needs to be designed to handle 400V DCFC, which adds extra complexity. As an example, the Taycan includes a 50kW HV DC-DC (150kW optional) just for 400V voltage DCFC.
DBC
Don
Volt ELR
I think you've explained the GM method of changing the battery configuration to enable 800v charging.
EVmodeler
EVmodeler
Doug
SW Virginia
Engr Prof emeritus
And there are 750V nominal DC systems - trains and subways.
