Mobile Charger / Engineering Minds Requested
chimpster23
22 BLK GT ER-AWD / 04 Toyota Camry
Mounted the bracket on wall but the mobile charger just comes right off when I pull the wire to the car
Currently being held up by my pressure washer to relive downward tension
Not much wiggle room due to the metal conduit in the way
I don’t have any tools to bend the conduit
Any ideas on what I can do to get this to work?
Ford Mustang Mach-E Mobile Charger / Engineering Minds Requested 1C6E3C1C-35B3-4AAD-932A-765AE718F10D
Ford Mustang Mach-E Mobile Charger / Engineering Minds Requested FFB54B73-6770-43D4-A826-2F58D7FE8216
Ford Mustang Mach-E Mobile Charger / Engineering Minds Requested 4F4ED8BF-0333-4020-9016-00C47054DF99
chimpster23
chimpster23
unfortunately it snaps off even without me touching it in some cases.
DadzBoyz
Oldsmar, FL
22 Mustang Mach-E GTPE (ordered), 20 Mazda CX-5
Software Systems Integrator
I'd do the following:
1. Loosen the bracket
2. Run two velcro straps between the bracket and the wall
3. Tighten the bracket
4. Wrap the velcro straps around the charger
I started to suggest zip ties, but the plastic zip ties may not hold up well with the heat from the charger and you'd have to replace them every time you wanted to take the charger with you.
Is it the tension from the pigtail plugged into the outlet that's pulling it off the wall? Can you mount a board of some kind next to the conduit to bring the bracket out so that it's flush with the outlet?
Mount the bracket to the conduit WITHOUT screwing into it. You could glue it, or do something with contoured wood blocks and zip ties.
ChuckA
Chuck
North Branford, CT
Accountant-Retired
Your problem is the bracket is too far from the plug which is a cord that doesn’t bend. Attach a 3/4 inch block over the conduit, below the outlet, and then attach the bracket to the block.
ChuckA
Chuck
North Branford, CT
Accountant-Retired
Or, rotate the socket 90 degrees and mount the bracket along the side of the outlet. Nothing says the mobile charger needs to be under the outlet.
devmach-e
SF Bay Area
Unix Sysadmin
Ummm, could the bracket that is supposed to hold the Mobile Charger be upside down, and that's why it keeps popping out?
MisterSofa
Jerry
Valley Forge
2021 Toyota Corolla, 2022 Ford MachE Premium AWD
It seems that the outlet was installed too low. I think it should be a minimum of 4’ off the floor or so my electrician said.
AKgrampy
Fairbanks, Alaska
Unplug Ford EVSE
Place back in bag
Store in trunk for emergencies
Purchase a wall mount EVSE
Mount above your outlet
Might sound cynical but there are a few threads where the Ford EVSE has had issues over time.
Otherwise just mount something behind the bracket (wood, etc) so that the cord from outlet to EVSE does not put pressure on the outlet or EVSE.
superdave80
Santa Rosa, CA
2022 Mach E Select SR RWD
I just flipped my outlet upside down due to it being so low to the ground. I don't charge much at home but it has worked fine for me.
chimpster23
chimpster23
IL code is 44 inches
chimpster23
chimpster23
Nope top part hits the short neck and snugs a fit. Just the wire keeps moving causing it to slip off
chimpster23
chimpster23
Imma try this. Thanks!
I’m sure menards has straps like this I can use
