joebruin77
- Joe
- Sep 9, 2021
- California
- '22 Mach E GTPE, '23 BMW iX xDrive50
When I first got into car detailing, I also struggled with getting the inside of the windshield clean. I came across this really helpful video from a guy named Chris Fix (link is pasted below). He recommends a 3 step process to super clean the interior of your windshield:Any recommendations on how to clean the inside of the windshield without creating tiny micro-scratches that in direct sun make it awful to see through? I'm hesitant to touch my MME windshield after previous experiences on other cars. I've used Turtlewax microfibers with some Windex in the past.
1) Wipe down the interior windshield glass with a clean, dry microfiber towel. I find that using a towel specifically designed for cleaning glass works best.
2) Next, wipe down the interior glass with a wet, activated magic eraser or with rubbing alcohol. Dry with another clean microfiber towel.
3) Finally, clean the glass with your favorite automotive glass cleaner. Conclude with a final wipe with another clean dry microfiber towel.
Glass is actually really hard to scratch. Usually the only thing that scratches glass are rock chips that hit the windshield at a high rate of speed on the outside.
If you are seeing those annoying marks in direct sunlight, I would suspect one of two causes. Either those are little fibers left behind by previously used microfiber towels. That is why I recommend using towels specifically designed for glass cleaning (or as others have mentioned, newspaper). Glass cleaning towels and newspaper do not leave little fibers behind.
The other explanation is that the outside of the glass has tiny marks or scratches. If that is the case, you can try clay barring the outside of the glass. If that doesn't work , then you might need to polish the outside of the glass using a dedicated glass polish and glass polishing pad with a DA machine polisher.
