Utahridge
2021 Ford Mach-E Premium 4x
Order, at least of these two recent updates, seems to be irrelevant as they update different things (technically I think 1.4.0 would make since updates that were later superceded by 1.6.0 but from what I've seen, getting 1.4.0 doesn't walk back any 1.6.0 changes).
As far as scheduling, not all updates require scheduling, these will go through wherever certain criteria are met. Seems a lot of updates are getting pushed now, likely clearing up stuff before a bigger update .
As far as your warnings, my only guess is part of the install requires rebooting of various modules. Depending on when the install happened, the reboot sequence might have been interrupted, causing some modules not to report properly, therefore you get the warning light.
Advice would be to take to dealer, get it documented. I'd guess the warnings would all go away after a period of the car being shutdown, plugged in, and later restarted... But that's just a guess.
My first thought was that I had interrupted the updating of the modules after starting the car.
I hope the errors clear up in the coming days and I will try to get by the dealer to get the incident documented.
Thanks for the advice.
BMT1071
Glendale, AZ
21 MME SR RWD, 23 MME GTPE
Machine Control Specialist
Utahridge
BMT1071
Glendale, AZ
Thanks for the heads up on the service bulletin.
I will be very disappointed if I need to take the vehicle to the dealer to fix a module that was obviously corrupted by the application of an OTA. The whole idea of OTAs is the vehicle can be updated WITHOUT having to take it back to the dealer.
They are likely unrelated and just an unfortunate coincidence.
Utahridge
I appreciate the insight. Thanks again for the Service Bulletin. It gives me something to reference if I have to return to the dealer for a service visit.
LandSpeed
Ron
MA
2021 Mach E Select IB
Updated to 1.6 with no issues. (I have Auto Update on w/o a schedule)
Is there a link to find out what changes are in the update? (Ford doesn't give any info)
Thanks
Nugatti
Aleksander
Norway, Sweden, Denmark
2021 Mach E
Got the Power-up 1.6 today, 2021-09-15. Strange how it arrived much later than for some others. Might be because I'm in Sweden.
I feel like it included updates to the MobileEye EyeQ4 module, as the cruise control lane keep assist no longer hugs the right side of the lane so much, but keeps the car more centered in the lane. Still not far enough to the left for my liking, but it's an improvement.
Tobi8424
Tobias
ZĂĽrich
Mustang Mach E & Renault Grand Scénic
Journalist
Same here in Switzerland. Must be because those Yankees keep mixing up the two countries ;-)
VegStang
Leo
Silicon Valley
Volvo C40 Recharge, 2021 MME
It appears that 1.6 fixed a problem connecting wireless CarPlay to the new iPhones that came out today, at least it would not work yesterday before the update, now works as expected.
VegStang
Leo
Silicon Valley
Looks like the new 13 isn’t supported fully for PAAK, message pops up saying there may be reduced functionality, unable to setup backup start code. So I guess it will be just flaky as usual. ? I can unlock, lock, and start the car so I’m good.
jetermeyer
MA
Lexus NX 300H, Acura TLX
The only time I have seen it go back to up to date so far, is just before a new OTA came out.
It was possible it was actually downloading an OTA at the time I checked.
Mine did exactly that. Said 1.4 for a long time. Yesterday just said up to date with no version. This morning I have 1.6.
ZuleMME
Zule
Denver, CO
21' Job1 P4X MME, 22' MYP
Implementation Engineer
I just got 1.6 on my late June build today…
2021-MMEx-RT1
CA
2021 MMEx CA Route 1
Yes
Me too! Finally an OTA for eVee...
Updated FordPass last night, today at the office I see an 'alert' and it says "Update Successful"
So my first OTA is 1.6.0, which seems will kick 1.4.1? then finally 1.7.1
and maybe that will kick my SYNC screen to stop glitzing out...
