Phone As Key issues
The Apple Watch app works fine for me although all it can do is turn the car on/off and lock/unlock the car. It also receives messages such as "fully charged." My watch is a current version--series 6.
So the Apple Watch works for PAAK?
methorian
Roanoke, VA
IT Admin
No - it does not. It is not a standalone app, so it must be connected to your phone, and only then does it allow remote lock/unlock/start just like FordPass on your phone.
I do get FordPass notifications occasionally through the watch app as well, but again they're just passed through from the FordPass phone app.
mikeho
San Jose, CA
I've been having problems with the Ford Pass app on my iPhone (iOS 14.4) and PaaK. Force quitting the app and restarting it seems to fix the problem every time, so I think what happens is that the app freezes, so it can't re-establish the bluetooth connection when I approach the car. I hope they can fix this and make the app more reliable.
  • Like
Reactions: DBC
mike
2016 Mustang
Everything was fine on mine. I set up phone as key added to my profile every thing worked great, until. Went to setup my wife's profile added her phone to the car set up, added her phone in her profile and checked if her phone would work as key and it did. Went to android auto and everything went down hill from there. Phones would shutdown and start back up. Fordpass app became unstable it also would startup and then shut down. I tried removing phones and profiles and start over but the same thing started again. I had to do a factory restart on my phone to even get it work at all. Removed the Fordpass from both phones. Tried to start the process over but nothing worked. Finely did a reset on the car system. Set up profiles again, added the phones. Reinstalled the Fordpass app to the phones and went to add phone as key. It got to the point where you push the tab to pair the phone, it was to copy and past the pairing code in the next step but it did not do it. I had to enter the onetime code manually, once I did that everything went along fine. I rejected the android auto setup and everything works just fine. I suspect the android auto has a virus or a bad code line that crashes the whole system.
Garbone
Gary
Loafer
My cheap Android Blu will not phone as key, tried tried tried, her cheap Android Blu set up as PaaK fine and I finally was able to program a start code. Her phone actually functioning as PaaK, nope, it has more to do inside the FordPass app now but I think the bluetooth is too lazy to do the job proper.
Good news, we have door codes and Start Passwords set up so we can survive if we loose our one FOB.
$44000, hey, lets cheese it with a single fob.
CopperRobot
Jason
United States
Ford Mach E
PAAK won't even show up in FordPass connected phone. Google Pixel 5. When adding vehicle it all connected, got confirm email, message in app confirming activation. Uninstalled everything on phone, reset keys on car. Reinstalled, still no option to add phone as key. Two fobs is a must from Ford. Can't rely on PAAK. Android auto won't really connect fully either. Bluetooth is connected, phone, media works but seems a little wonky.
JellyBelly
Kris
MME RR FE
Hope all those with PPAK not showing up are calling Ford and getting it logged as an issue. If not they wont see the magnitude of the problem. I am sure they know the issues but magnitude hopefully elevates the urgency especially since they made the decision to only give one fob.
mikeho
San Jose, CA
I'd like to call it in or send an email, if possible. Do you have a phone number or email for customer support?
Frank Katz
Frank
Santa Fe, NM
2004 Prius 2016 Crosstrek
Ret'd
I still plan to give Ford the benefit of the doubt and will act like PAAK will keep working fine. I'll leave the fob at home and use my phone with the codes as a backup. I'll see if my trust is misguided.
However, I plan to trust but verify. Resetting and re-connecting PAAK requires having the fob and the permanent door code. When we travel to FL in a couple of weeks, I assure you that the fob will go with us!
Frank Katz
Frank
Santa Fe, NM
Ret'd
I have set up PaaK and tried to set up the Backup Start Code but after entering the code I wanted to use on the screen I couldn't figure out how to enter.
Any clue?
JellyBelly
Kris
MME RR FE
Any clue?
It will prompt for code if you enter the car without the fob or PAAK but just access the door with door key and then try to start. If you have a fob or PAAk, it will not prompt for backup code as far as I know.
prdude
pleasant ridge, MI
engineer
actually, I've had it happen to me on a few occasions where I approach with my phone (no key fob), and I know PAAK is working, because HAL welcomes me with the puddle lamps. Then, I'm able to unlock and get in. But then I go to start HAL, I get the "no key detected" message on the instrument cluster screen and a prompt for the backup code on the touchscreen .... obviously bizarre, since HAL let me unlock and get in. So, after opening the driver's door and closing it again, I'm able to successfully start it. I figure opening and closing the door must be waking up whatever module controls PAAK.
eltonlin
NorCal
FE Gray
My wife and I set up our PaaK and as part of that process the Backup Start code - we did this at the dealer.
However, when I enter with the passcode and attempt to start the car, I am NOT prompted to enter the backup code. Same with my wife's passcode.
Wondering if I need to remove the PaaK we setup and start again (heaven forbid). Only change I remember doing was assigning our profiles to a seat profile. No changes to PaaK at all (and our PaaK work generally fine).
