Plug & Charge?
jeremykraft
Jeremy
Seattle
2021 MME - Premium AWD Extended Range, Rapid Red
Is Plug & Charge working for anyone? I have my car linked to my Ford account and a credit card uploaded but whenever I plug into an EA charger, I need to use either my CC at the station or activate it through the app. And even that is really wonky.
DevSecOps
Todd
CISO
Works for me every time. I've never had it fail yet and I DCFC at least 1-2 times a week at EA. Always the same stations though and they are newer.
I took a trip to NC and used the same EA charger on the way there, and on the way back. Plugged in my car and it just started charging. No issues.
Accord07
Earth
Yugo
Plug and Charge has worked flawlessly for me at eight different EA locations.
hybrid2bev
2026 Rally
Did you turn on the switch in FordPass?
Your free hours should be on the previous screen. If they aren't there, that may be why you don't show EA.
DevSecOps
Todd
CISO
Yes? But it only shows GreenLots and not EA. No option to add it.
I remember when I enabled it said that you had to wait for EA to be activated. I assume it's been a while since you activated it so you might want to call Ford and ask them to look into why the activation never happened.
I think that screen shots explains why it's not working. It's not activated and therefore nope, ain't happening.
jeremykraft
jeremykraft
Jeremy
Seattle
Yeah - nothing on the first screen.
I did buy this Mach-E slightly used? Maybe that's the problem?
Ford Mustang Mach-E Plug & Charge? Screenshot_20220120-104123
DevSecOps
Todd
CISO
The charging balance has nothing to do with P&C. That's misinformation. Even if you have no balance P&C will work. It's likely that the activation was associated with the previous owners email (Ford Account). You're just gonna have to call Ford and have it straightened out.
If it's used, then the hours are probably long used up. As to why it doesn't work on EA chargers, I suspect that the account needs to be reset by Ford. I'd contact Support via the app.
lwilliams0514
Lashawn
Gardena, CA
2021 Ford Mustang Mach E Premium RWD
Finance Manager
I have been noticing that if the EA charger was around when the EA was added to the FordPass for plug and charge, it works perfectly (if the charger is not experiencing issues). If it is a newer EA charging station, those are not in the FordPass app at all. If they are, it does NOT use plug and charge. Sounds like Ford and EA need to get together and refresh the list of stations that allow plug and charge.
jeremykraft
jeremykraft
Jeremy
Seattle
Talking to Ford support right now. First response was that I needed a $50/year EA subscription to get it activated as part of Plug & Charge? That doesn't seem right.
It is not right. And they meant Plug and Charge, not EA. That fee is for the discounted EA and other networks. P&C is free for 2 years.
