I'm more inclined to think that the FP app is not updating the time elapsed.
the script is working with the data it has available which is the same exact data used by the FP app
It's weird that it's spot on with FP app and suddenly they skew
Yeah, something happens when the age of the data hits 1 hour that makes the last refresh timestamp reset. But FordPass must not be using that because it continues counting correctly. Very odd.
Goober96
Brent
SC
2021 Mach-E4X, 1996 Mustang Cobra, 2008 Corvette
Well, those steps are included in the instructions :)
Also, for anyone still copying/pasting the script every time there's an update, I recommend you follow @tonesto7 's note about saving the script file to iCloud. Overwriting the file there is easier than copying and pasting since Safari doesn't natively support Select All.
I tried to save the file but apparently need to be on a computer to do that. I use an iPad. I just searched and found a way to add “select all” to Safari instead.
Goober96
Brent
SC
Long press on the link to the file and select Download linked file.
I tried that but it downloads the HTML page instead of the file.
Goober96
Brent
SC
Gullwingdmc
Chip
Boston, MA
Release v1.3.1
  • Fixed Oil Life showing no data.
  • Fixes for timestamp offset text at the bottom are offset too much.
  • Shows warning for Low Oil Life and low oil.
  • Fixed issue with advanced control menu going to wrong sections when only certain items were shown due to the vehicle capabilities.
  • Fixed the Alerts not allowed in widget error (this is really shown because the saved VIN is invalid)
  • Fixed repeated login prompt because of the deviceLanguage variable missing from the setUserPrefs call. Removed the requirement as it's not being used right now
Download Link:
https://raw.githubusercontent.com/tonesto7/fordpass-scriptable/main/Fordpass Widget.js
Instructions:
tonesto7/fordpass-scriptable: FordPass Widget for Scriptable (github.com)
What's Next?
  • Slowing down on features and focusing on stability.
  • Working on small widget layout.
Community:
Discord: https://discord.gg/VPw3zw9v
Thank you for doing all this work!! I can’t wait to try it out.
If I could throw out a UI suggestion?
Could you simplify the door and window status to just a single “Closed” status when all are closed, and only break them out to individual statuses when one or more are open. This would just simplify the UI as most of the time your windows and doors are closed.
SAM
SAM
Central NJ
Premium MME4X Iconic Silver
I've been updating that way. Use open with and open the .js file with TextEdit, paste new script and save. It's easier.
Holy Driver
Lars
Germany
Mustang Mach-E RWD SR
The script is working so far now for me.
Except the widgets have problems.
I can only use the small one.
Middle and large aren't working.
Will provide screenshots at evening (CET) when usefull.
hetgeleteken
Martijn
Utrecht, NL
VW Golf Estate, Ford Mustang Mach-E AWD ER Lucid Red Tech+ reserved
Same here, only the small one works, large and medium ones won't show up when selected in Scriptable.
tonesto7
Anthony
Ann Arbor, Michigan
2021 F150
Software Developer/System Admin
Release v1.3.2 (12/20/2021)
  • Fixed issues with distance and pressure units not matching those set in FordPass app settings (Only refreshes when values are missing and every 5 minutes).
  • Fixed vehicle image when multiple versions of the script are selected.
  • Fixed the status message left offset when there were any messages.
  • Fixed some unhandled variables errors.
  • Updated the WebView titles to remind users that their personal info (VIN, address, position, etc) has been scrubbed from the data they are viewing.
Download Link:
Instructions:
What's Next?
  • Script Updater (Might just use https://scriptdu.de but it doesn't support multiple instances)
Community:
tonesto7
Anthony
Ann Arbor, Michigan
2021 F150
Release v1.3.3
  • Fix for some vehicles reporting rear windows with a status of undefined and showing open in the widget.
  • Fix for some vehicles not having the windows status for front windows.
  • Other fixes to handle undefined values in the vehicle data.
Download Link:
Instructions:
What's Next?
Community:
tonesto7
Anthony
Ann Arbor, Michigan
2021 F150
I almost have an installer tool working which means no more copying the script anymore.
You will install a single script FordWidgetTool and it will install and update to the latest version on every run.
I hope to have it ready for testing by the end of the day today.
SMHart
Boston MA
2021 Mach E Premium
I wish I could say I am savvy with this stuff but alas, I am not. I did get the medium widget up though, so thank you!!!
On that note I’m posting to say I did initially have the same issue Sam mentioned about not being able to find the widget on my Home Screen, not even the widget for scriptable.
So a little digging and I went in to my settings, settings for scriptable app and changed the language ( i chose German) and low and behold it popped up as a choice for a widget I could add now. I don’t know why this worked but just something I found online and it worked in case it helps someone else.
  • Like
Reactions: SAM
