Logal727
C
ā€˜21 Carbonized Gray Mustang Mach-E Premium AWD Ext
Looks like the OTA Status is gone from the Ford site, which is causing the widget to return no results and the Debug Menu just pops up again..
oliverames
Oliver
Vermont, United States
Mach-E Select Dual Motor Standard Range
I’ve noticed this as well. Haven’t gotten it to work all day, except for a period where I got one pop-up that says ā€œUnknown Errorā€
Logal727
C
Wonder if they hid it
Gullwingdmc
Chip
Boston, MA
Looks like they just changed some of the info. The script is looking for certain values and those may have changed. This is what I see when I pull the raw data on mine.
"ccsStatus": {
"ccsVehicleData": "On",
"ccsConnectivity": "On"
"otaAlertStatus": "YOU ARE ALL SET",
"displayOTAStatusReport": "UserAllowed",
"updatePendingState": null,
"error": null,
"fuseResponse": {
"languageText": null,
"fuseResponseList": [{
"communicationPriority": "High",
"deploymentFinalConsumerAction": "Not Set",
"vin": "MYVIN",
"tmcEnvironment": "PRD",
"type": "REGULATORY",
"oemCorrelationId": "FLARE-PRD-SOFTWARE-FNV2-479584-493492",
"deploymentId": "b52c8f51-3c5d-495c-8c5c-efe3766db02e",
"deploymentCreationDate": "2022-01-19T19:34:45.250+0000",
"otaTriggerExpirationTime": "2022-01-19T05:10:35.239+0000",
"inhibitRequired": false,
"deploymentExpirationTime": "2022-01-26T19:34:45.250+0000",
"triggerType": "SOFTWARE",
"additionalConsentLevel": 1,
"latestStatus": {
"aggregateStatus": "success",
"detailedStatus": "OTAM_S1010",
"dateTimestamp": "2022-01-21T07:28:44.707+0000"
"packageUpdateDetails": {
"failedOnResponse": "none",
"wifiRequired": false,
"cdnreleaseNotesUrl": null,
"updateDisplayTime": 0,
"packagePriority": 1,
"releaseNotesUrl": "https:\/\/mmota.autonomic.ai\/1\/bytestream\/custom-release-note-1639090617339-6d97bb15-9027-468d-96d1-0d3569cb933c"
"tappsResponse": {
"status": 200,
"asuActivationSchedule": {
"dayOfWeekAndTime": null,
"activationScheduleDaysOfWeek": [],
"activationScheduleTimeOfDay": null,
"tappsDateTime": "",
"vehicleDateTime": "",
"oemCorrelationId": "",
"scheduleType": ""
"vin": "MYVIN",
"vehicleInhibitStatus": null,
"lifeCycleModeStatus": {
"lifeCycleMode": "NORMAL",
"oemCorrelationId": "0",
"vehicleDateTime": "2022-01-03T15:11:24Z",
"tappsDateTime": "2022-01-03T20:11:47.196Z"
"version": "2.0.0",
"asuSettingsStatus": null
oliverames
Oliver
After this, I looked and was able to pull the raw data. It does indeed look slightly different. Some new values and other values have gone completely.
Code:
    "ccsStatus": {
        "ccsConnectivity": "On",
    "error": null,
    "fuseResponse": {
                "vin": "3FMTK1SS3MMA25355",
                "oemCorrelationId": "FLARE-PRD-SOFTWARE-FNV2-479584-494588",
                "deploymentId": "89612cdc-977d-4386-af4c-f862861d9ff0",
                "deploymentCreationDate": "2022-01-20T17:27:09.368+0000",
                "deploymentExpirationTime": "2022-01-27T17:27:09.368+0000",
                "latestStatus": {
                    "aggregateStatus": "failure",
                    "detailedStatus": "OTAM_E1016",
                    "dateTimestamp": "2022-01-21T00:48:50.254+0000"
                    "releaseNotesUrl": "https://mmota.autonomic.ai/1/bytestream/custom-release-note-1639090617339-6d97bb15-9027-468d-96d1-0d3569cb933c",
                "deploymentFinalConsumerAction": "General Failure Will Retry"
    "tappsResponse": {
        "status": 200,
            "vehicleDateTime": "2022-01-14T15:05:55Z",
            "tappsDateTime": "2022-01-14T20:06:16.551Z"
            "scheduleType": "",
            "tappsDateTime": ""
        "asuSettingsStatus": null,
        "version": "2.0.0"
Gullwingdmc
Chip
Boston, MA
Code:
    "ccsStatus": {
    "error": null,
    "fuseResponse": {
                "latestStatus": {
    "tappsResponse": {
        "status": 200,
            "scheduleType": "",
            "tappsDateTime": ""
        "version": "2.0.0"
Ya most notably the release notes.
oliverames
Oliver
There is also a third one of these. Trigger expiration time.
mikeinet
New York
Standard AWD Tech/Comfort
I think that's the latest released version. You have to manually paste the script for 1.5.0.
Edit: Sorry, I meant to past the link to the script, not the entire script here.
What's the easiest way to copy and paste this manually??? Struggling with a "select all" concept
Jlt50
James
Arkansas
2021 Mustang Mach-e
Category manager
Can still see data on ota in the View Vehicle Data Output section of the widget.
You can email it to yourself from a computer. You should be able to use select all from there. Or you can save the script file directly to iCloud.
tonesto7
Anthony
Ann Arbor, Michigan
2021 F150
Thanks for catching this... This must only occur after the specific OTA 2.3.0+ my last update was 2.1.0 and my OTA data still shows.
I will add checks for the new structure into the upcoming version.
oliverames
Oliver
I don't have 2.3.0 but did have a failed attempt. Only 2.1.0. so far.
Gullwingdmc
Chip
Boston, MA
Weirdly mine still looked the same after 2.3.0. I got that last week and this changed for me in the last 2 days. Let me know if you need the JSON.
Logal727
C
I have a feeling this won't be accessible for much longer...
