Rj786
Raza
Niagara Falls Ontario Canada
2022 Mustang Mache Premium
i had the same issue and a permanent fix was done by my Ford dealer as per TSB below.
TECHNICAL SERVICE BULLETIN
Wind Noise From Exterior Mirror/A-Pillar Area When Driving Between 25 MPH-40 MPH (32 Km/H-64 Km/H) - Built On Or Before 09-Jul-202424-2230
25 July 2024
This bulletin supersedes 24-2002. Reason for update: update the symptom, production fix date and the Service Procedure
Model:
Ford
2021-2024 Mustang Mach-E
Built on or before 09-Jul-2024
Markets: Canada, USA
Issue: Some 2021-2024 Mustang Mach-E vehicles built on or before 09-Jul-2024 may exhibit a wind noise from the exterior mirrors/A-pillar area when driving between 25 mph-40 mph (32 km/h-64 Km/h). This may be due to poor sealing of the lower mirror foam and the glass top run foam. To correct this condition, follow the Service Procedure to install new lower inner foam and the glass top run foam.
NOTE: A small amount of wind noise from around the exterior mirrors is considered to be characteristic of vehicle design.
Action: Follow the Service Procedure to correct the condition on vehicles that meet all of the following criteria:
• 2021-2024 Mustang Mach-E
• Built on or before 09-Jul-2024
• Wind noise from exterior mirrors/A-pillar area when driving between 25 mph-40 mph (32 km/h-64 km/h)
Parts
Service Part NumberClaim QuantityPackage Order QuantityNumber in PackageDescription
164-R4901​
3 Per Affected Side​
1​
12​
PVC Soft Foam Strips (Rotunda Part Number)
Parts - Parts Only Applicable To Vehicles Built On or Before 06-Nov-2023
LJ8Z-5820530-C​
1 Per Affected Side​
1​
Lower Inner Foam
Claim Quantity refers to the total number of individual pieces required to repair the vehicle.
Package Order Quantity refers to the amount of the service part number package(s) required to repair the vehicle.
Number In Package refers to the number of individual pieces included in a service part number package.
Warranty Status: Eligible under provisions of New Vehicle Limited Warranty (NVLW)/Service Part Warranty (SPW)/Service Part New Vehicle (SPNV)/Extended Service Plan (ESP) coverage. Limits/policies/prior approvals are not altered by a TSB. NVLW/SPW/SPNV/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
Labor Times
DescriptionOperation No.Time
2021-2024 Mustang Mach-E: Install New Lower Inner Foam If Required And The Glass Top Run Foam On One (1) Side Includes Time For Road Test (Do Not Use With Any Other Labor Operations)
242230A​
0.9 Hrs.​
2021-2024 Mustang Mach-E: Install New Lower Inner Foam If Required And The Glass Top Run Foam On Both (2) Sides Includes Time For Road Test (Do Not Use With Any Other Labor Operations)
242230B​
1.4 Hrs.​
Repair/Claim Coding
Causal Part:5820530
Condition Code:07
Service Procedure
1. Perform a road test to identify if the wind noise is coming from the exterior mirrors/A-pillar. Does the vehicle exhibit a wind noise coming from one or both exterior mirrors?
(1). Yes - proceed to Step 2.
(2). No - this article does not apply. Perform normal diagnostics. Refer to WSM, Section 100-04.
2. Lower the front door window glass of the affected side to the fully down position.
3. Remove the exterior mirror. Refer to WSM, Section 501-09 Rear View Mirrors > Removal and Installation > Exterior Mirror Assembly.
4. If the exterior mirror foam gasket/seal remains on the door, remove and refit the mirror foam gasket/seal back onto the mirror before reassembly. (Figure 1)
Figure 1
Ford Mustang Mach-E Side Mirror Wind Noise Fix imagen2
5. Separate and fold back the front door glass top run from the door frame and the run channel in the areas highlighted in Figure 2.
Figure 2
6. Is the vehicle built on or before 06-Nov-2023?
(1). Yes - proceed to Step 7.
(2). No - proceed to Step 9.
7. Remove the existing lower inner foam.
8. Install the new lower inner foam.
(1). Insert the front of the foam first making sure is seated under the window run/sheet metal and the foam shape properly fits the curves of the door. (Figure 3)
Figure 3
(2). Evenly tuck all edges of the foam into the door making sure that the rear sections sit flush against the window run frame with no gaps. (Figure 4)
Figure 4
9. Print the foam template by clicking this link. Verify the horizontal and vertical scale of the image using a ruler against the scale on the template printout (Figure 5) to confirm the image scale is correct. Is the scaling of the template printout the same scale as the ruler?
Figure 5
(1). Yes - proceed to Step 10.
(2). No - adjust scale of the printing properties to actual size to resize the image. Repeat Step 9.
10. Layer together 3 pieces of the PVC Soft Foam Strips to obtain the desired thickness.
11. Cut the shapes from the template printed out and trace the shape of the back side of the foam. Cut the foam along the line traced on the back to create the shape indicated in Figure 6.
Figure 6
12. Cut an additional 10 mm (0.39 in.) slice into the foam in the area indicated in Figure 7.
Figure 7
13. Remove the existing glass top run foam and clean the surface to remove any residual foam. (Figure 8-9)
Figure 8
Figure 9
CAUTION: Be careful to not tear the rubber of the glass top run when fitting/tucking the foam underneath.
14. Install the cut pieces of foam onto the glass top run.
(1). Align the foam with the ridge along A-pillar and the lip along the header. (Figure 10)
Figure 10
(2). Apply pressure to adhere the foam to the inner surface of the glass top run. (Figure 11)
Figure 11
(3). Fold and pressurize the lower area of the foam over the back of the A-pillar channel, leaving the upper extension unadhered. (Figure 12)
Figure 12
(4). Moving to the exterior of the glass top run, take the end of the foam extension and pull, seating the foam toward the header/A-pillar corner. (Figure 13)
Figure 13
(5). Tuck the end of the foam extension high up under the lip of the glass top run following the upward angle of the run. (Figure 14)
Figure 14
15. Reinstall the front door glass top run in the door frame and the run channel. (Figure 15)
Figure 15
16. Reinstall the exterior mirror. Refer to WSM, Section 501-09 Rear View Mirrors > Removal and Installation > Exterior Mirror Assembly.
© 2024 Ford Motor Company
All rights reserved.
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford or Lincoln dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supersede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources.
Rj786
Raza
25 July 2024
Model:
Ford
Parts
164-R4901​
1​
12​
LJ8Z-5820530-C​
1​
Lower Inner Foam
Labor Times
242230A​
0.9 Hrs.​
242230B​
1.4 Hrs.​
Repair/Claim Coding
Causal Part:5820530
Condition Code:07
Service Procedure
Figure 1
Figure 2
Figure 3
Figure 4
Figure 5
Figure 6
Figure 7
Figure 8
Figure 9
Figure 10
Figure 11
Figure 12
Figure 13
Figure 14
Figure 15
Rj786
Raza
25 July 2024
Model:
Ford
Parts
164-R4901​
1​
12​
LJ8Z-5820530-C​
1​
Lower Inner Foam
Labor Times
242230A​
0.9 Hrs.​
242230B​
1.4 Hrs.​
Repair/Claim Coding
Causal Part:5820530
Condition Code:07
Service Procedure
Figure 1
Figure 2
Figure 3
Figure 4
Figure 5
Figure 6
Figure 7
Figure 8
Figure 9
Figure 10
Figure 11
Figure 12
Figure 13
Figure 14
Figure 15
CameraCarl
Karl
Twin Cities
This seems like a very complicated fix. I worry that my local dealer would be able to remove and reinstall all these parts without introducing squeaks and rattles which may be worse in the long run than the wind noise.
voxel
Nelson
Altamonte Springs, FL
22 Mach-E 4X, 23 GC Limited
For the last few months I’ve had tape covering the gaps around the mirror (like the TSB) and it does reduce the wind noise over the mirror but does not fix the wind noise over the driver’s side ear. That is noise is caused by multiple gaps not covered by the TSB.
* the top of the windshield and the glass roof
* the glass roof and the frame
* between the door and the frame (which may never have a good solution)
I put insulation and tape over the first two and reduce the driver side ear noise such that I'm not reaching for the window button constantly (lol).
RonOinAZ
Ron
Phoenix, AZ
2022 Premium 4X & 2025 Premium
Had a bit of a eureka moment and I think I've found the perfect compromise solution between spline (which works just ok for noise) and the thick rubber strip, which works better but is ugly. I had some of this U-shaped rubber left over from an unrelated project and it hit me after a road trip (during which I was still hearing more wind noise than I should) that it might fit nicely into the mirror gap. And wow, not only is it a good fit but it works GREAT - ZERO noise - and it doesn't look like sh*t.
I also want to express gratitude for this solution. I'd had the wind-noise TSB done on my car and it may have made a little difference but the majority of the noise didn't go away. I tried your solution this week and couldn't be happier. Not only did it resolve the wind noise problem, it practically eliminated the road noise from other cars along side of me and passing me on the road. That was noise I had just accepted as being normal until now. It's a great improvement so thank you very much.
My driver's side came out similar to yours:
Ford Mustang Mach-E Side Mirror Wind Noise Fix 1726425854982-ks
I decided to do the passenger's side as well but there wasn't room for the trim rubber to fit so I compromised. It doesn't look as good but it should stays put:
Ford Mustang Mach-E Side Mirror Wind Noise Fix 1726426029239-ht
Jeff-NoVA
Northern VA
2022 Mustang Mach-E Premium
Well done,and I'm happy this solution helped others. I found that by gently using a metal hook to hold up the rubber trim up at the top I was able to tuck the top edge of the rubber strip in, which I think really gives it a finished appearance.
Here is that top edge today, months after I installed it:
Ford Mustang Mach-E Side Mirror Wind Noise Fix IMG_5820
RonOinAZ
Ron
Phoenix, AZ
Oh, OK. That's the reason for trimming that end of the rubber. I hadn't quite understood that part. Now it's clear. I'll do it. Thanks!
Update: Done
Ford Mustang Mach-E Side Mirror Wind Noise Fix 1726459261622-b8
Bruboy
Bruce
HTX
Semi-retired
My car is getting close to it's 10K Mile Service and was wanting to get everything scheduled.
Did you have the Wind Noise TSB done and did you notice a difference after the repair was done?
medriver
ME
Make sure to give them as much notice as possible on the TSB because they "will have to order the parts" and they "might not be ready" when you actually bring your car. The most likely outcome will be they will figure out your car meets the criteria for the TSB, then never order the parts and forget to call you....and I go to the "good" dealer around here.
RonOinAZ
Ron
Phoenix, AZ
I had the wind noise TSB done in July this year. The difference I sensed was the front motor whine was reduced. In August last year I'd had the whine-related TSB done, and it reduced the whine some. The wind noise TSB seemed to reduce the whine even more but it didn't do much for the wind noise. The solution that significantly reduced the wind noise is the one offered by Jeff-NoVA above.
lifebythemile
Metro Vancouver
2023 Mach E Select RWD - Vapor Blue
I had the TSB done within 3 weeks of owning the car. It just made it worse. Before I couldn't hear it over the rain on a really wet day, now I can....
Bruboy
Bruce
HTX
Semi-retired
My exact concern, I'm coming up on 10K Mile Service and am debating what to do.....
Bella
Bella
Sweden
Mach e rwd er 21
Married
Voxel! You described my three exact problems. My car used to be amazing and silent.
But suddenly all these things appeared after i went to service. I taped my mirrors with a slight reduce in wind noise.
The wind noise you describe from your left ear i have that one too and people who are sitting behind me say their window sounds like its open. When cars go past my left hand side i can hear them loud and clear compared to the right one. Can you please send pictures of where you taped to get a reduce on sound level?
My drivers door list goes slightly more inwards than the passengers behind my i tried to tape it with no luck?.
I also have the windshield/pano noise hoping to get that fixed with the dealer. The frame/panel above my head i can feel it vibrating in high speeds around 90km/h
