Slow Charging
shutterbug
Joseph
AZ
Mine is plug-in. I also cannot change that. The co-op presets some things before they give it to you.
Mine is grayed out when the ChargePoint is connected to the car.
guinn
guinn
Guinn
SW Colorado
2021 AWD Select Standard Range; 2023 AWD Premium
Retired but active
my CP charger at home is giving me 9.2kwh consistently when set at 50A
Good to know. I'm going to have to experiment more to see if the charger is having a problem or if the car is doing something strange.
krafty81
Terry
I don't think you're getting 11kW at 40A lol. That would mean voltage of 275V+. At 48A with a 60A breaker I would believe that.
Thanks all. I have a 60A breaker w CP set at 40A. My app showed a charging rate of around 9 kw. Just looked at the chart again. 65kwh in 9 hours. Got me to 90%.
breeves002
St. Louis, MO
2021 Mach-E GT PE
If you're hardwired you can set it to 48A with that 60A breaker assuming its a flex.
guinn
guinn
Guinn
SW Colorado
Retired but active
As a follow-up to my original post: It turned out that the CP charger was the problem. A factory reset fixed the issue, and the Mach-E is now charging at 9kW. Thanks to all of you for your knowledge and assistance. BTW, the lady at CP who helped me was both knowledgeable and very friendly. Kind of refreshing!!
Crilly
Dale
Hartland, Wi
I always thought the vehicle controls the charging rate. The closer it gets to full the slower it charges.
Is there away to tell the mach e what rate I want it to charge at?
mjschillingtec
MJ
Mach E GT Grabber Blue; BMW 328i Convertible
Business
If you have a NEMA 14-50 receptacle, you shouldn't be using a 60A breaker.
if it is a plug in what breaker should i be using? I am on a 60a and my charging seems very low. I only got 35.45 kWh over a 9h52m period of time.
BMT1071
Glendale, AZ
21 MME SR RWD, 23 MME GTPE
EV Technical Trainer
What did you set in the app?
As the General stated, the "50" in 14-50 means 50A max.
It should also be noted that the breaker size will not affect your charging rate (unless it trips!).
Without more information (what EVSE you have, state of charge before/after, was the car actually charging the entire time....) it's hard to be more specific.
