Software updates, manual or automatic?
circatee
Georgia, USA
Mustang Mach-E GT PU, 2025
Curious, those of you with a Mach-E, do you let the system auto update, or do you search for updates and install them?
I know the Mach-E isn't like an iPhone. However, I tend to let my iOS devices update on their own.
Alas, I am a little more hesitant to follow the same process with the Mach-E. Hence, this post.
Thoughts...
ArthurDOB
Arthur
High School Teacher
Search for updates and install them? I don’t even think that’s possible without FDRS. You’ll have to OTA it like the rest of us.
I set up automatic updates.
If the vehicle notifies me that an update is pending for overnight install, then if I happen to be at home I'll tell it to update right away rather than waiting, because I'm a nerd. ?
I just have automatic updates set and throw FDRS at it once in a while. ?‍♂?
hybrid2bev
2026 Rally
I may or may not check my vehicle in the PTS system multiple times per day looking for the Notification of Update Pending status. Some might say that I’ll then quickly walk out to the garage to start the car (trigger the OTA download). Then perhaps it could be said that I’ll restart the car again later to finish the installation.
Thoughts...
Your understanding is not accurate.
Your vehicle only updates when Ford queues up an update for it.
If you turn Auto Updates off, then you won't get any. If you turn it on, and there is no update queued up for your vehicle, then you won't get anything.
You cannot "search for an update".
When an update is available, it's downloaded to your vehicle and applied. That's unless it requires the vehicle to be immobile, which then reverts to the schedule that you have set. If you don't set a schedule, clicking "Update Now" will then apply the update after a 2 minute countdown.
I'm sure I'll be corrected if I misstated anything. I suspect that "use FDRS" isn't what you had in mind based on being a new owner and the questions you've been asking.
circatee
circatee
Georgia, USA
...this breakdown is SPOT ON! Cheers.
