EV_Vida
- Simon
- Sep 25, 2022
- San Diego
- Mach E CR1
Thx Mike for all your help! One last question before I actually do it.If you got the Clore PL6100...that is probably the most recommended powersupply. Not sure what you mean by battery supply setup?
You mean how it's all connected?
If you've done the holesaw mod you just connect the terminals and initially set the PL6100 to charge until your state of charge is over 80% and then switch over to powersupply mode at 14.0V.
If you haven't done the holesaw mod you just remove the frunk rear and left side beauty panels and connect, then the rest is the same. If you are going to keep up with all the updates I recommend doing the holesaw mod for quicker access.
For the Battery my settings should be:
TYPE: AGM
RATE: 10A
plug it in and watch it charge to 80% and then switch over to supply and change to 14volt, is that correct?
