UK Customers
webby75
Paul
UK
BMW 220i & BMW 330e
Financial Adviser
Looks like a good fit, the rear bar does looks a bit close to the front one… but I guess the roof line stops it from moving more towards the rear of the car? A fellow roadie too… nice Bianchi btw ??‍♂??
RegP
Reg
UK
'23 Mach-E, AWD ER
The kit gives all the measurements, distance from windscreen and distance between bars. I agree they do seem a bit close, but absolutely solid. ?
webby75
Paul
UK
BMW 220i & BMW 330e
Financial Adviser
Yes, I saw the 700mm gap and 210mm from the windscreen measurements, a roof box may look a little off balance. The Bike rack looks ok though. Still no idea of the roof load limit though from Ford?
Wonky_Donkey
Tony R
Norwich UK
2022 Mach-E RWD ER
These FordPass app updates are like my local supermarket… you just learn where everything is, and then they go and move everything around so you can’t find anything!
Welcome to FordPass v4 ?
SashaLondon
Sasha
London
MME AWD SR
Developers can’t add anything else of note so they move stuff around to justify their pay ……
coolshades
UK
Jaguar XF -> Mach E AWD ER, Rapid Red
I never expected to see more than 200 miles in winter! Bodes well for the warmer months
Ford Mustang Mach-E UK Customers Screenshot_20220206-070604_FordPass
Jonno21
Derby, UK
Mach-E AWD Long Range Space White
Interesting... Mine reads 190 miles at 90%. Are you down South by any chance? I'm in the Midlands which is north of Watford. ?
Mwjdavies
Martin
Uk
Mach E RWD SR Rapid Red
Ford Mustang Mach-E UK Customers 981D587F-F254-4AC5-AAA9-D2056EF2C2DC
I live not far from Liverpool, and this was from Thursday. Oh and this is Standard Range NOT Extended Range :D
Wonky_Donkey
Tony R
Norwich UK
2022 Mach-E RWD ER
I’ll play the game too - but remember I live in the tropics of Norfolk where it’s a sweltering 10°C right now - plus I’ve had the latest software update that makes the GOM less pessimistic…
Ford Mustang Mach-E UK Customers CA5133F1-1FAD-487E-968B-E4E25E2B08FB
tbone77
London
Mach e
Property developer
Does anyone else have a problem with the rear seatbelt warning sound going off even if nobody is sitting on the seat? Lat night I collected my daughter who directly behind me in the rear RH seat and the warning sounds started going off for the other seatbelts. I told her to make sure that the seats were clear, which they were. I managed to fic it but turning the car off and on again at the traffic lights.
David-HC
UK
MME RR ER RWD ?
There are actually two APIM module updates available on FDRS at the moment for most Job 0 early build cars (Nov 2020 - Jun 2021)
The first one will update your SYNC software to the equivalent of PowerUp 1.7.1 and should show a software version of 21174 - 168 in Settings --> General --> About SYNC
The second APIM update requires the dealership to directly connect to the APIM module in the car via a micro USB cable to re-flash it. Its a bit of a fiddly job as they have to remove a panel in the footwell / dashboard to access it.
If you get both of those updates you should be all good and ready to accept Power-Up 2.1 when it gets released for your VIN over the coming weeks.
I've attached a table below to show the SYNC versions after the respective Power-Up updates. As you can see Power-Ups don't always update the SYNC software, sometimes (eg 2.1) they update the software on a different module which you won't be able to see through SYNC.
Power Up VersionSYNC Version
1.3 & eCall FSA#21C16???
1.421139 - 263
1.621139 - 263
1.7.121174 - 168
2.121174 - 168
2.321281 - ???
Hi @Wonky_Donkey
Hope all is good in the tropics of Norwich ?
Thanks for the table of Power-Up and Sync versions!
This was really helpful as I had been slightly confused since, having received my 2.1 update a couple of weeks, I received a Ford Pass notication last week that I had been updated to 2.3 ...... but the car still showed 2.1 ?
I noted on one of the other US forums that there was a potential issue with the 2.3 update still showing in the car as 2.1 - and using your table I checked and am on Sync 21281-244 which relates to Power-Up 2.3 ? I also checked and have some of the changes specified for 2.3 e.g. adaptive cruise control changes.
Much appreciated,
Wonky_Donkey
Tony R
Norwich UK
2022 Mach-E RWD ER
Hi @Wonky_Donkey
Much appreciated,
Now I’ve got 2.3 FOMO - I’m still in 2.1 ?
David-HC
UK
MME RR ER RWD ?
FordPass 4.1.0 is available for iOS in the Uk.
Hi @SashaLondon
Thanks - I checked and it's also available for Android ?
As has been pointed out, appears to be mainly moving options around .................... but in my case, after three months of logging an issue of not being able to see my charging schedules on Ford Pass - they are now visible again ?
Have to make the most of these little "victories" ?
Cheers
portlandg
grahame
Dorset UK
Black RWD ER and loving it
Cabinet maker
That's assuming it works in the first place. ?
