UK Customers
SashaLondon
Sasha
London
MME AWD SR
I’ve got 1.7.1 fomo it’s not working. I can’t even go into all the other updates.
SteveUk
Warrington
Mustang Mache with crap keys
Does anyone else have a problem with the rear seatbelt warning sound going off even if nobody is sitting on the seat? Lat night I collected my daughter who directly behind me in the rear RH seat and the warning sounds started going off for the other seatbelts. I told her to make sure that the seats were clear, which they were. I managed to fic it but turning the car off and on again at the traffic lights.
I believe you have to have the middle seat belt clicked in even if the seat is empty if you have anyone in the back. As this is due to no sensor being there in the middle. I think.
coolshades
UK
Jaguar XF -> Mach E AWD ER, Rapid Red
Interesting... Mine reads 190 miles at 90%. Are you down South by any chance? I'm in the Midlands which is north of Watford. ?
I am almost midway between you and Watford.
g8mb1t
Godalming, United Kingdom
24 MME Premium AWD ER, former keeper of 21 MME First Edition
Hi all. Just a quick update on the roof rack situation. I bought everything from Thule.com and all is well. However, I believe that there is no roof load weight for the EU market and it appears the kit I got is no longer on the Thule website. I’ve not finished the fit off completely, not installed the locks or rubber strips yet, but I can confirm it all fits correctly and that part numbers etc. are correct.
Nicely done did the same got the kit from Thule US site
Ford Mustang Mach-E UK Customers E500E716-5473-4F91-85AB-F4E4E0805747
Ford Mustang Mach-E UK Customers 2ACA5162-D3C3-4674-9A8C-FC2663478041
Robinsbcfc
George
Chesterfield
Ford Mustang Mach E RWD ER Rapid Red
Could someone please tell me the best setting for heating controls in the Mach e
Wonky_Donkey
Tony R
Norwich UK
2022 Mach-E RWD ER
Set it to a single bar of AUTO and then let it look after itself ?
neiloakley
UK
Mach E RWD LR
Thank you appreciate the support
It’s a decent answer, your question was a little vague. You didn’t say what you wanted ‘best’ for? Comfort, range etc.
for range - pre-heat whilst plugged in, turn off e-heat and use heated seat and steering wheel.
for comfort - keep on auto.
Tony.T
Tony
Bodmin uk
Toyota C-HR sadly gone, MME RWD ER now with us!
There are actually two APIM module updates available on FDRS at the moment for most Job 0 early build cars (Nov 2020 - Jun 2021)
The first one will update your SYNC software to the equivalent of PowerUp 1.7.1 and should show a software version of 21174 - 168 in Settings --> General --> About SYNC
The second APIM update requires the dealership to directly connect to the APIM module in the car via a micro USB cable to re-flash it. Its a bit of a fiddly job as they have to remove a panel in the footwell / dashboard to access it.
If you get both of those updates you should be all good and ready to accept Power-Up 2.1 when it gets released for your VIN over the coming weeks.
I've attached a table below to show the SYNC versions after the respective Power-Up updates. As you can see Power-Ups don't always update the SYNC software, sometimes (eg 2.1) they update the software on a different module which you won't be able to see through SYNC.
Power Up VersionSYNC Version
1.3 & eCall FSA#21C16???
1.421139 - 263
1.621139 - 263
1.7.121174 - 168
2.121174 - 168
2.321281 - ???
Hi @Wonky_Donkey. Thought I'd check my sync version and this is what I've got!
Any ideas?
Ford Mustang Mach-E UK Customers Sync 4
SteveUk
Warrington
And E heat is a strange setting in that it auto turns on (forced) if you put the blowers manually to the top only.
neiloakley
UK
Mach E RWD LR
Mine doesn’t do that, I frequently have the blowers on full and e-heat has never come on
