UK Customers
Teslaeata
Nottingham, England, UK
Thanks for the replies.
Anyway, it’s my Mach-e ’s 1st Birthday today!
Mine would’ve been 2 on Friday if Ford didn’t place that hold on deliveries, sales, demonstrating etc due to the e call IT mess up!
It turned up 58,000 miles today and due to be going in for service if it don’t find itself burned out in a lay-by before?
Puddle light lenses deteriorated, transmission whines unless that’s in my head and “park brake error service now” message appears on dash more often than not which I found is because left rear park brake no longer applies.
Stangy’s poorly.
Might be tent & pistol time!!!
SteveUk
Warrington
Mustang Mache with crap keys
My screen brightness control no longer works since it went in for s/w updates last week and often starts in night mode so I can't read the screen and it won't kick out of it.
Wonky_Donkey
Tony R
Norwich UK
2022 Mach-E RWD ER
Stangy’s poorly.
Looks like you may have fallen foul of the brake harness wiring issue.... ☹
https://www.macheforum.com/site/thr...tronic-parking-brake-harness-connector.27496/
There is a UK version of this TSB but I don't have access to PTS right now to pull the article for you. Your dealer should know about it as it was on one of the daily bulletins just the other day.
Wonky_Donkey
Tony R
Norwich UK
2022 Mach-E RWD ER
So I've got an odd little thing going on in my Mach-E right now too (seeing as we are defect listing ? )
A couple of weeks ago I noticed a dried liquid spot/stain on my right boot near the toe - thought nothing of it at the time.
More recently this week I noticed a dried brownish colour spot of liquid on my right trainer - in exactly the same place as the one I noticed on my boot. I've now looked at all my shoes and I have the spot on the ones I use for driving. Non driving shoes are all clear.
Checked the footwell for any signs of leaks from above - can't see anything there that may be contributing. Dreaded trip to the dealership?
Paul weston
Paul
Worcestershire
Mach e SR RWD
Can anybody help me figure out why my car charges outside of the preferred charging times? I have it set to charge between 23:00 and 03:00 but as soon as I plug it in it will start charging.
It will usually stop at 03:00, but it just won't wait until 23:00. It's super annoying.
I've tried removing and re-adding the saved location, clearing any settings in the app and trying the same in the car. I just don't understand what is going on.
SteveUk
Warrington
Sadly yes!
Paul weston
Paul
Worcestershire
Mach e SR RWD
Hi
From what I can see you are trying to charge from 43% to 90% within a 4hr time slot, which if you have a 7kwh home charger is not possible. I charge mine from 1:00 to 4:00 on a cheap rate tariff and get around a 25% charge, 4hrs should get you around 35 to 40% I would say. Hope this helps
Teslaeata
P*ss poor!
The sort of thing my 1973 Vauxhall Viva would've suffered from back in the day, not what I’d expect of a supposed state of the art electric vehicle, if they can’t weatherproof wiring carrying milliamps at low voltage with the consequent risk of defective brakes, and their main contactor is already proved to be poorly designed & manufactured, how can anybody have confidence in the product!!!!
Wonky_Donkey
Tony R
Norwich UK
2022 Mach-E RWD ER
P*ss poor!
Ford Mustang Mach-E UK Customers IMG_3107
Oldlawman
Essex UK
"Rosie" - Rapid Red Mach E AWD EXTD
I recently contacted Ford Customer Service about the lack of updates here and you might be interested in the response I received.
Ford Mustang Mach-E UK Customers IMG_8161
Ford Mustang Mach-E UK Customers IMG_8160
Ford Mustang Mach-E UK Customers IMG_8159
Ford Mustang Mach-E UK Customers IMG_8158
Teslaeata
You’d think somebody who could spell and is literate would be put forward to provide official responses??‍♂
Wonky_Donkey
Tony R
Norwich UK
2022 Mach-E RWD ER
It’s a pretty hard email trail to make any sense of, and it’s littered with the same factually incorrect responses from Ford that we have gotten so used to ? (how do they manage to get it so wrong?)
@Oldlawman - you left your vehicle VIN number on the email screenshot so I took the liberty of doing what Ford customer services are incapable of doing and looked up to see what dealership software updates have been applied to your vehicle since it was built - the answer is none. The good(ish) news is you are running on a relatively new factory build and are running SYNC Version 22082 right now.
If you want to delve deeper feel free to send me a direct message and I’ll do what I can to help.
Oldlawman
Essex UK
Cheers mate. I received one over the air update months ago - the first half of the Alexa installation. God knows where t’other half is! What I’m really after (like everyone else) is the volume knob update to allow easier heater control etc.
portlandg
grahame
Dorset UK
Black RWD ER and loving it
Cabinet maker
It all depends on how you are charging and with what equipment. I use the supplied variopower charger with the commando 32amp plug. I set my car to charge between 0100 and 0400. If the amount of charge requested is more than the car will accept in the time period set then it will start charging as soon as you plug it in. It will work out how much it will accept between the set hours and turn off until 0100. For example, if you want it to accept 90% charge and you have 25% in the car, in 3 hours it will "roughly accept 15 - 20% so it will charge from 25 to 70/75% as soon as you plug in. It will then turn off and start again at the set time. If you ONLY want it to charge during set time you have to reduce charge % accordingly. Hope this helps.
