When will Mach-E owners be able to open the frunk using Fordpass app?
2021-MMEx-RT1
CA
2021 MMEx CA Route 1
Yes
The real question isn’t whether it’s an eject button, but rather, whether it’s upwards ejection or downward ejection. One is an E ticket for the passenger, the other a mess and probably a bit rude.
Yeah, good thing there isn't a stick shift nearby...
PeeKay
Pravin
Sunnyvale, CA
2021 Job 1 MachE
The safety release button inside the frunk should have a electronic release, right? If that is the case there should be a path for software to control it.
I haven't figured out how to move the hood lock into the locked position, to test out the button with the hood open.
Anyone tried this method?
That doesn't work in Job 1 cars either. That was the reason for the dividers in the frunk. It's easy to test, just hit the button with the frunk open and you can hear the servo if it's working. (spoiler: it isn't)
PeeKay
Pravin
Sunnyvale, CA
2021 Job 1 MachE
Got it. So if the button is present, it was designed to work with the motor. So is the mechanism absent in job 1's? I wonder ....
jonkMACHE
JK
NYC
MME 4X
When will Mach e owners be able to open the frunk through the ford pass ? Anyone know
I use this functionality probably a few times a week
And 100% of the people who can do that own 2021 Job 2 or later vehicles. No job 1 car can open the Frunk by any method other than double pulling the mechanical release.
NJ Steve
2021 Mach E
Totally agree!! I doubt if I pop the hood open more than once a month and that’s just to top off the washer fluid. Opening it manually works just fine for me!
I totally agree about the need for remote activation of the frunk. On the issue of washer fluid, when I use the washer I get a heavy smell of alcohol inside te cabin. Anyone else notice this or is it an issue with my MME?
VegStang
Leo
Silicon Valley
Volvo C40 Recharge, 2023 MME
I noticed on my Job 1 car a while back that I started hearing the electric release on the first or second pull of the handle. It may have been there before but I don't remember hearing it and thought it started happening with one of the last sw updates. Still looking forward to using the phone or screen to get this working.
1969Camaro
Scottsdale AZ
2021 Mach E Premium, 2018 Prius Prime, 1969 Camaro
I tried it and it works.
I am just kind of gobsmacked to learn that the RHD cars have the mechanical frunk release on the left side of the car. WTH, Ford? ??
noway
Norway
2021 Mach-E First Edition
Software developer
The hardware module for the frunk release is called "Generic Function Module", GFM, and it is present on the job 1 cars. It seems to not have any other features than controlling the frunk release. As all cars has the 12V booster frunk opener wires at the front the release mechanism and relays also are present and functioning. If I remember correctly from looking at the schematics the 12V booster wires at the front bypasses the GFM and control the relay directly, so only thing missing is the activation of the signal from the GFM controlling the same relay
