markboris
- Mark
- Nov 13, 2019
- Sonora, CA
- Currently: '20 Shelby GT500 FPB '24 Mach-E GTP GGM
- Retired
It's true you can't change the charging amperage in the ChargePoint app once you have set it up. ChargePoint took that feature out of their app because home owners that were clueless, were setting up their chargers incorrectly.People keep pushing the ChargePoint charger, but I keep reading how cumbersome it is to changing the charging amperage. With the JuiceBox, I can change the charging amperage, in the JuiceBox app, in seconds. If that's a feature you want, then ChargePoint isn't a good choice.
However, you can easily change the charging amperage anytime by using the ChargePoint Service Pro app. This app's only function is to change the amperage in the HomeFlex charger. Open the app while standing next to the charger which connects via Bluetooth, select the amperage you want, confirm and you're done.
