04/04/22 Build Week Chat
dark_ma773r
Dark
VA
(Mach-E on the way Jun16-22 2022), Tacoma TRD PRO
Cybersecurity
So happy you are enjoying your car!
I have also been considering getting a tint. I only have to charge once a week around the city (it drops from 100% to 60-67%). Learning one pedal driving has been a god-send for battery regin. I am getting better at it, but it makes a huge difference.
I need to learn the one pedal ways as well. Will take some getting used to.
CarDreams
CarDreams
Charlotte, NC
Mach-E ER Premium 2022
I have been using 1 pedal driving for so long (have a Model 3 ATM), I try to use it in my wife's CX-5 and other ICE cars lol. End up doing a lot of coasting, maybe it helps a bit ?
I did a lot of coasting in my Prius C, it had regin breaking. The Mach-E seems to break more aggressively and its LEGIT twice the weight of my last car, so its been a lot of me learning how to time the coasting with the added weight and different breaking systems.
DrJay32
Jason
Colorado
www.luminescentphoto.com
2022 Mach-E Select AWD
Photographer
I was using it at first, but it gets me into trouble when I'm in a parking lot or stopped at a light because my brain has been wired for the last 30+ years to NOT use the gas pedal and just use the brake when backing out of parking spots. I almost rear-ended someone at a stoplight because my brain thought my foot was on the brake and pressed it when I was actually using the accelerator pedal.
You can get lots of regen in Unbridled mode, even with 1PD turned off.
NJ_MachE
I've been hesitant to turn it on for the same reasons. Considering the 'brake scores' I keep seeing flash across the console, I'm using Regen about 95-100% of the time even without OPD.
CarDreams
CarDreams
Charlotte, NC
I've had a couple of close calls and moments when I'm like, "why isn't this car working?!" And of course it's user error haha. One pedal driving was difficult the first couple of weeks but now I don't think about it much. I have had to use the break sometimes in heavy traffic. Someone threw on breaks yesterday and I had to use it then, for example.
I heard about the regen in unbridled mode. I'll have to try it.
DrJay32
Jason
Colorado
Photographer
Muscle memory is real.
MachEMaster
Will
Canada
1997 GMC Yukon GT
Aircraft Maintenance Engineer
Hilarious @DrJay32
Every time I pass a gas station I think, do I need to fill up.....mmmm nope?
Finally got my gate programmed on my homelink!! Yaaaaa. Garage was easy peasy. But gate was being difficult ?. Going to go on my first mini road trip today. 1 hr away. Excited to show my daughter Storm Trooper?
I had a heck of a time with my garage. Once I finally got it working, my outside keypad on the house didn’t work. Doh!
Mach_E_avelli
2022 Mach-E Select SR RWD
If you press the "L" button on the gear selector, it will give you regen. I think the idea is for it to act like a "low" gear, which would be beneficial going down hills (I live in Delaware, we don't have hills) but it also acts as a fairly aggressive regen brake when not on the throttle. It won't stop the car, but will slow you down considerably.
CarDreams
CarDreams
Charlotte, NC
An update on the recall, my VIN now populates on the main NHTSA site. Its actually pretty clear language on what could go wrong. Still no notificaiton on the main Ford app or in the Ford recall section of their website. If anyone is interested:
https://www.nhtsa.gov/recalls
2022 FORD Mustang Mach-E
Ford Mustang Mach-E 04/04/22 Build Week Chat no-class-image-not-availabl
Recall data refreshed on Jun 18,2022
1 . Unrepaired Recalls associated with this VIN
Jun 13,2022
Manufacturer Recall Number: 22S41
NHTSA Recall Number: Awaiting#
Recall Status: Recall Incomplete, remedy not yet available
Summary: ON YOUR VEHICLE, IT MAY BE POSSIBLE THAT THE HIGH VOLTAGE BATTERY MAIN CONTACTORS MAY OVERHEAT, WHICH CAN RESULT IN AN OPEN CONTACTOR OR WELDING CONDITION.
Safety Risk: SHOULD THE CONTACTORS WELD CLOSED WHILE DRIVING, A POWERTRAIN MALFUNCTION WARNING LIGHT WILL BE ILLUMINATED ON THE NEXT DRIVE CYCLE, ALONG WITH A NO START CONDITION. IF THE CONTACTORS OPEN WHILE DRIVING, A POWERTRAIN MALFUNCTION WARNING LIGHT WILL BE ILLUMINATED, THE VEHICLE WILL DISPLAY STOP SAFELY NOW IN THE INSTRUMENT PANEL CLUSTER, AND THE VEHICLE WILL EXPERIENCE AN IMMEDIATE LOSS OF MOTIVE POWER. THE VEHICLE WILL COAST TO A STOP, AND ALL 12V SYSTEMS INCLUDING POWER BRAKES AND STEERING WILL REMAIN FUNCTIONAL.
Remedy: FORD MOTOR COMPANY IS WORKING DILIGENTLY TO DEVELOP SOFTWARE FOR THIS REPAIR. WHEN SOFTWARE IS AVAILABLE, FORD MOTOR COMPANY WILL BEGIN DEPLOYMENT AS A FORD POWERUP SOFTWARE UPDATE AND WILL ALSO NOTIFY YOU VIA MAIL OF THE OPTION TO SCHEDULE A SERVICE APPOINTMENT WITH YOUR DEALER FOR REPAIRS TO BE COMPLETED FREE OF CHARGE PARTS AND LABOR. SOFTWARE IS ANTICIPATED TO BE AVAILABLE BY END OF Q3 2022.
Manufacturer's Notes: TO CHECK FOR NON-SAFETY-RELATED PROGRAMS APPLICABLE TO YOUR VEHICLE, SEE HTTP://WWW.FORD.COM/ OR CALL YOUR FORD DEALER."
DrJay32
Jason
Colorado
Photographer
Thanks for sharing.
I think that the part people (in other threads) seem to be missing is what Ford didn’t say.
They didn’t say “stop driving fast”
They didn’t say “stop using DCFCs”
They simply mentioned that those were the conditions that could cause problems in affected cars.
Of course, then you have to cue up all the conspiracy theorists… LOL.
As someone who’s had cars subjected to safety recalls in the past, most often times the number of affected vehicles (ones that exhibit the issue) is a lot fewer than the number recalled. For example, I had a “faulty door latch” recall on my 2014 Escape. I never had an issue with it, and it never exhibited any signs of the defect. But Ford replaced it anyway.
I know it feels like Russian Roulette, but I’m still thinking that while very real, the actual # of cars with a potentially faulty part is low.
Either that or I’m just a fan boy drinking the Kool-Aid again.
Happy Sunday!
Enjoy your MMEs!
Shenred
NC
2022 Premium AWD EX
As a bit of a change of topic, has anyone elected to get some form of paint protection through their dealership? If so, what was your experience with it, and do you think it was worth the extra cost?
I had been considering getting ceramic coating or PPF sometime after taking possession. However, my car is currently sitting in recall jail at the dealership. I'm contemplating whether now is a good time to get it done since I don't have to worry about being without a vehicle or getting damage prior to getting something done.
FrostyICE
Michele
Magnolia
Mach E ordered, Taurus, F150
Pro mom
I've been using unbridled 1 pedal and getting used to it. After reading ur msg, I changed to different setting and can only see the regen message when I'm not in 1 pedal. What gives? It doesn't or can't tell us "all the time"?
FrostyICE
Michele
Magnolia
Pro mom
Can't for me. A. Don't wanna spend the money right now. B. Don't Wanna be w/out my car, I will cry. C. I could be wrong, but heard it only lasts 8 months?‍♀.
But hey sounds like it's a no Brainer, if u wanna "pony" up the cash?. Is it worth it, idk.
Electricponi
Sherine
Rav4
RN
I got PPF and ceramic coating privately done. Paid $3.5k, my mind tells me it was a total waste, but it’s been done, no going back. Let’s see how well it holds up.
CarDreams
CarDreams
Charlotte, NC
I guess I need to switch to unbridled since it's so popular!
Ford Mustang Mach-E 04/04/22 Build Week Chat 20220619_195850~2
Sonic has been out soaking up the sun on these summer road trips.
