12 Volt Battery - External charging - Maintainer
Ken Josing
Ken
Moorpark, CA
2021 Ford Mustang Mach-E
I've seen many posts regarding the 12 volt battery, but none on how to hook up a maintainer. I think I know the easiest way and would like to confirm so my battery stays at 85% or better when away to eliminate the problems that are coming from low battery status, I've had none. I'm thinking the access door to the left of the front license plate. Hook the maintainer to the two available wires. I use my maintainer on my ICE machines and that is the greatest tool. My oldest ICE machine battery is over 8 years.
AKgrampy
Fairbanks, Alaska
My understanding is those wires only connect when the battery is dead. So can’t use them for your application.
Correct, you cannot charge your battery with those wires, they simply unlock the frunk IF the battery is dead. You will need to run cable from the jump points to somewhere to plug in. On my F-150, I ran to a wheelwell and tucked the connector behind the splashguard while driving.
You would need to create some sort of jump points. The two leads in the front bumper are not connected to thee 12V battery. They only operate the frunk release when the 12V system is dead. There are safety reasons why Ford didn't place live 12V out in front of the bumper. ??
Ford Mustang Mach-E 12 Volt Battery - External charging - Maintainer IMG_2943
Ford Mustang Mach-E 12 Volt Battery - External charging - Maintainer IMG_2944
This is a much nicer solution compared to the holes most of us cut in the cover. I love the fact the dealer has used the holes and I saved them from having to remove the cover when they did my last FDRS updates. This is a must have mod, either holes or your much more polished version.
I need to recondition my LVB. It is good to do that once a year IMO. I did it a couple months after bringing the car home, and now I need to do it again. I think I will do it tonight.
Ken Josing
Ken Josing
Ken
Moorpark, CA
I like this access point, Ford should have made this standard. Where do we get one of these?
Given that 12v issues have been resolved, anything more than cutting holes and putting in plugs is really unnecessary, as is a 12v maintainer unless it's sitting for months.
Auto Motive
Doug
Valencia Pa
I will be removing the cover over the 12v battery and cut the positive and negative symbols on the cover holes to expose terminals.
su-ch+mache
carl
Germany
www.ford-suv-freunde.com
Escape MY17, Puma MY20, Mach E MY22 AWD ER TP2
retired buyer
Hi, today I added a charging cable to the 12 V battery in order to attach my maintenance device CTEK MSX 5.0
was quite easy and done in 30 minutes.
and a DIY
parts used:
CTEK adapter cable
cable protector
Ford Mustang Mach-E 12 Volt Battery - External charging - Maintainer Pole
hawkeye3point1
NH
and a DIY
I did something similar, but ended up removing it because it was quite conspicuous and was not sure how dealer techs would react to it. Also, I think it is only really needed for desulfation, which is not required that often.
One recommendation, install the neg. lead on the chassis ground stud where the neg. battery cable terminates. Connecting on the battery itself can adversely impact how the car maintains LVB SOC. There is a device built into the neg. battery cable that is affected if the charger is connected directly to the LVB.
I recommend jumping the end of that cable to the chassis when lifting the cable to avoid resetting modules that require standby power. Otherwise you will have to check all of you settings.
su-ch+mache
carl
Germany
retired buyer
@hawkeye3point1 thanks for your advice to install the neg to the chassis ground stud.
I somehow can't take the cover out it is quite well fixed. Any advice on how to take it out without damaging it?
hawkeye3point1
NH
Start at the back near the windshield where it is thin, pry gently to get the first blind fastener to pop, then feel your way to the next and lift up as close to it as you can, rinse and repeat. There are fasteners on both sides of the hood prop cutout.
