12v - Increase charging
Gistrup
Steffen
Denmark
Mustang Mach-e
Hi, just wonder if there is anything I can do to increase the automated charging of the 12v battery from the main battery, to avoid regular manually connection of an external charger. I understand that the 12v battery must be at, at least 80% to receive and install any updates without failure. That's why the voltage level is important to me. Mine is normally around 70% and every updates received are failing and I don't want to manually charge the battery every week.
E.g. leave the car on in parking mode for some hours with aircon and heater disabled? (my dealer suggested that, but does it work?)
Charging the car with a Grandmother charger, will give the car time to transfer power to the 12v battery? (ChatGPT suggested that!)
Leave the car in sleep mode for several days?
Delete the Fordpass app from my phone, to avoid waking up my car?
Which method is most efficient if any?
Easiest is to use the 120v charger. Last 2 options are ridiculous.
Leaving the car running while parked will charge the 12V battery regardless of the HVAC settings.
Triggerhappy007
TX
23 Premium, 3rd Mach-E
Yes, it's mainly to decrease battery usage when parked and on. If OP is planning to do that, make sure to disable auto shut off after 30 minutes.
JohnFoxeSheets
San Francisco
johnfoxesheets.com
I've successfully used the HVAC & lights off, car on, auto-shut-off disabled approach many times. Of course you should only do this if you can secure the car from theft. But I would only do that if/when there is an update queued up. Doing it on a regular basis would be overkill and might not be healthy for the 12V battery.
As for charging it with an L1 charger, that can also potentially work, but you need to consider such as traction battery SoC (needs to be low enough to allow the 12V to charge, while high enough that you get the range you need for your commute). If your situation happens to fall in that sweet spot, then yeah, it can work just fine...
Ford_orr
orr
Los Angeles
Hellraiser
As has been suggested, I periodically (once a month or six weeks) leave the vehicle on in my driveway for 8-10 hrs. Turn off auto lights, turn off auto shutoff, turn off Bluetooth.
kkgg
Minnesota
mach e
I downgraded my chargepoint current limit to 20 amps. that way it will charge slowly but also charge the 12v battery for the entire time.
My car is 3.5 years old now and I do not have any 12v battery issues.
ipca204
ooooohhhhhhhhhh, you did it now! You have angered the 12v battery gods.....incoming issues...imminent!
Shayne
Northern Ontario Canada
2021 MME4x Prem
Scheduled updates should give you a notification it has an update so before is a good time to put it on your 12V charger. Mine has updated with a 15 amp hooked up.
Just close the ford app and tell your phones system to not allow it to do anything in the background. You can shut off notifications so the app does not tell you closing it down is bad. That should save some phone and car battery for you. You then just have to open the app for it to work as a key/controller which is the only small minus.
Gistrup
Gistrup
Steffen
Denmark
Mustang Mach-e
Hi again! Would it be enough just to connect a charger to the 12V battery during the time it takes to run an update? Or will I only receive updates if the 12V battery is highly charged?
AtomicInternet
SC
Focus RS, Mach E Rally
Extending the charge time will keep your 12v charging longer, but it sounds like you leave your car unattended for several days. If that's the case then the "grandmother" charger is a good idea since your car will not charge for multiple days.
I'd recommend some battery terminal rings to connect to your 12v so you can plug/unplug the tender more conveniently than pulling the car apart every time you use it.
https://www.amazon.com/Battery-Tender-081-0069-6-Terminal-Disconnect/dp/B000NCOKZQ/
And this tender is $14 currently, so you'd be $24 all-in for a disconnectable battery tender.
https://www.amazon.com/MOTOPOWER-MP00205B-Automatic-Battery-Maintainer/dp/B07TDWJ9VW/
If you drive your car every day you shouldn't need this, but again from what you've written it sounds like you go several days without starting. This would be easiest in that situation.
rreddy3
Richard
2023 Mach e Premium AWD X
I have connected my CTEK charge/tender prior to an OTA when the 12v battery SOC was somewhere in the 75-78% range. After connecting the CTEK I selected the update now option on the center screen. I’ve done that once or twice and the OTAs were successful. Will that work every time, was I just lucky, I don’t know.
Folks, please remember to schedule your OTAs (rather than clicking on "Update Now") if you have low 12V battery issues. That allows the 12V battery to precharge in the hours before the scheduled install on supported vehicles. Select a time in the middle of the night when you will not be driving the car so it has idle time beforehand.
If that doesn't work, other methods include slow-charging the HVB (install the update after it's been charging the HVB for 3+ hours) or leaving the car on before manually applying the update. If you still have trouble, it might be time to replace your 12V battery so OTAs have enough power to install.
You may not have to go to the lengths of buying a 12V battery charger; the car can charge the 12V battery itself. The scheduled OTA route is meant to be the easiest for successful installs.
