Adding a Physical Interior Liftgate Power Switch
JohnFoxeSheets
San Francisco
johnfoxesheets.com
The only way to trigger the Frunk beside using the main screen is the button inside the frunk. That button connects to the Generic Function Module (GFM) behind the center screen (slightly below it). It’s a real pain in the ass to get to. Moreover, if you use that button to pop the frunk, it will display an alert on the IPC letting you know that button was used and to check the frunk to make sure nobody was stuck in there.
I’ll dig up a wiring diagram shortly.
Thanks!
Rickless
Eric
21' Mach-E 4 Premium
what sort of wisdom are you seeking?
Hi Pat - In short (kind of):
1. Do you have a link to the type of pins did you used to connect the wires to the respective harnesses?
2. What length of wire was required to connect the headlight switch to the Lift Gate Module?
3. How did you run the wire from the cabin into the lift gate?
4. Do the interior panels of the rear lift gate simply snap on and off, or is it more complex?
Thank you!
2021mustangdan
ON, Canada
2022 Mach-E Select RWD, grabber blue
Why add a switch when it is on the Ford Pass app, key fob as well as center screen? Would think doing changes to wiring would affect warranty as well.
i8iridium
Pat
Fort Washington, MD
2022 Mustang Mach E GT
U.S. Air Force (ret.)
Thank you!
1. Unfortunately, I don't know the spec of the particular pin. I had several connectors from a previous project that used the same pins. It's a female pin. It came out of the connector with part number WPT-1401. I'd have to buy another subscription for wiring diagrams to get specific pin part numbers.
2. I don't know the specific length. I do a lot of wiring projects, so i have a large bench stock of assorted wiring. It can be any small gauge wiring. There's hardly any current being carried across this wire.
3. I ran it down the driver side of the vehicle, following the existing wiring tray under the kick plates, up the C pillar into the headliner, then followed the rubber wire channel from the car body into the hatch.
4. I won't say they "simply" snap off. lol They do snap off, the clips are very strong, so you have to be careful.
I'm sorry I couldn't be really detailed. I'm not one for creating videos while I work, so most of this is an afterthought.
i8iridium
Pat
Fort Washington, MD
Some folks really like to customize their vehicles to fit their needs. For me, it's way easier to just push a button on the dash, then flip through two or three menus or pull out my phone.
As far as changing the Frunk wiring, I'm not real interested in that, but I can see value for other folks depending on their circumstance.
Speaking of Frunk wiring, @JohnFoxeSheets I've attached the wiring diagram I have for that.
JohnFoxeSheets
San Francisco
johnfoxesheets.com
Thank you very much, Pat! I really appreciate it.
EDIT: based on the wiring diagram, it would appear that if if BCM C2280E-15 & -22 are each pulled to ground (using a momentary NO DPST switch), that should activate the Frunk Release Relays which in turn should activate the Frunk Latch. Does that sound right to you? I'm not accustomed to reading this type of schematic (and am rusty at any schematic!)... All that said, I'm not sure what the Frunk Release Relay Micro does...? Does it get the kiddy-stuck-in-Frunk-panic signal from the GFM?
Thanks
i8iridium
Pat
Fort Washington, MD
Thanks
I'm not sure if it needs applied simultaneously or if it's a 1, 2 sort of thing because the release using the screen or PAAK is a two pull system.
Yes, i believe the GFM is what sends that signal over the MS CAN network to the IPC.
JohnFoxeSheets
San Francisco
johnfoxesheets.com
Good point about the potential 1 - 2 activation. I'll try to do some tests soon.
I just need to figure out where the heck I can take my car to work in the passenger foot well!
Ford Mustang Mach-E Adding a Physical Interior Liftgate Power Switch IMG_3504
The driveway certainly isn't an option...
Ford Mustang Mach-E Adding a Physical Interior Liftgate Power Switch IMG_3278
krazieboy
US
Mustang
Found a bit of time today to get this done. I can confirm that Ford Explorer part # LB5T13D061NB does work perfectly fine.
Going to add in the pix i took incase it helps anyone else out. I had some issues figuring out how to run the cable at first until i took off mutiple panels.
Thanks markboris and i8iridium for figuring all this out =)
Ford Mustang Mach-E Adding a Physical Interior Liftgate Power Switch 20220515_110147
Ford Mustang Mach-E Adding a Physical Interior Liftgate Power Switch 20220515_110152
Ford Mustang Mach-E Adding a Physical Interior Liftgate Power Switch 20220515_110413
I couldn't find the right terminal pin at the store, so i followed @coachluke advice and just shoved the cable into Pin 12 and taped it down to prevent it from moving. I still plan to try and find the right pin connector.
Ford Mustang Mach-E Adding a Physical Interior Liftgate Power Switch 20220515_113130
Popping the clips off is pretty easy. Use a small flat head screwdriver.
Ford Mustang Mach-E Adding a Physical Interior Liftgate Power Switch 20220515_115330
Ford Mustang Mach-E Adding a Physical Interior Liftgate Power Switch 20220515_115342
Ford Mustang Mach-E Adding a Physical Interior Liftgate Power Switch 20220515_115422
Ford Mustang Mach-E Adding a Physical Interior Liftgate Power Switch 20220515_115647
I tapped into the same brown cable like everyone else did. Just be really careful if you are using a blade to get the cover open.
Ford Mustang Mach-E Adding a Physical Interior Liftgate Power Switch 20220515_142548
I ran the cable through the bottom of the center console area. Lots of room there. I kept the cable under the carpet and then up the side towards the Headlight switch.
Ford Mustang Mach-E Adding a Physical Interior Liftgate Power Switch 20220515_143337
Ford Mustang Mach-E Adding a Physical Interior Liftgate Power Switch 20220515_153114
krazieboy
US
Mustang
And these do not fit!!
Ford Mustang Mach-E Adding a Physical Interior Liftgate Power Switch 20220515_143952
KevinS
I had some wire from when I was mucking with Arduino programming left over. Looks like this:
Ford Mustang Mach-E Adding a Physical Interior Liftgate Power Switch 002.JPG
This end has an inner sleeve that works great:
Ford Mustang Mach-E Adding a Physical Interior Liftgate Power Switch 003
I then removed the outer piece (it has a "pull-tab-ish" part you remove and it slides off:
Ford Mustang Mach-E Adding a Physical Interior Liftgate Power Switch 004
But don't do what I did and accidently cut the brown wire when trying to use a 3-way tap like this. It sliced through the wire like butter even though it was supposed to be the correct size:
Ford Mustang Mach-E Adding a Physical Interior Liftgate Power Switch 005
But I was able to splice it back together in a pretty ugly way. I had some serious butt-puckering going on at this point:
Ford Mustang Mach-E Adding a Physical Interior Liftgate Power Switch 006.JPG
And fortunately it's now working just fine. I may go back later and try to clean up and wrap the wiring hack I did at the wiring harness, but this was enough for one evening.
Ford Mustang Mach-E Adding a Physical Interior Liftgate Power Switch 007.JPG
JohnFoxeSheets
San Francisco
johnfoxesheets.com
So bye bye Max Defrost hard button since it's already on the center display. Nice!!
I don't see the need for an interior button for the liftgate at all. I'll use the main screen, the button below the liftgate, or kick the car in the rear end. But apparently, a fair number of people do see a need. All the more power to them.
krazieboy
US
Mustang
hmm.. i gotta dig though the ewaste at work and see if i can any good conects like that to use. didn't even think about pcs.
how did you wire the cable to the passeger side? did you go a similar route?
KevinS
I snaked behind the center console and then behind the dash under the steering wheel to the switch. It didn't occur to me to snake it under the carpet.
